Oh - looks like both HLCA cars are out for TT09. Shame really as I'd have liked to have seen how much the new fuel regs effected Glenney in the EVO, as they (EVO's) more than anyone seemed to struggle at TWP in Jan with the change.
But that sure leaves the modern comp wide open now.
Yes interesting times ahead with regard to what the fuel change will do.
Some scrutineering checking some engine capacities wouldn't go astray though....... look, this Evo even comes with a legal spec 2.0L engine as a spare! lol
http://www.my105.com.au/classified.asp?id=11538
Yeh but they weren't quick anyway... no one looks if your not winning!
that ad is gold. generally those discussion should be held off the internet.
It does remind me of a white road car of the same spec that used to follow a high profile race car. On the last night it had an engine swap with the race car. Wierd.
lol Dunc, something tells me I know the vehicle you're talking about....... shame the hottie engine was sold to someone else and was in someone else's race car last time I drove the car in question. LOL
Edit: just to clarify, this talk of a hottie engine is pure speculation Duncan, because personally, I think you have it wrong. I can only go by what people whom were actually there have told me while sober.
Edited by Marlin
For anyone that's interested the edited and approved Sup regs and Intention to enter forms for the 3rd annual Mt Stuart Rally Sprint in Townsville on the Queens birthday long weekend are up on our web site. Townsville City Autosports Club.
Probably the biggest change is lience requirement has been changed from National rally to Clubman rally.
Hope to see some of you there.
yeah that the engine was checked... weeks later in another city!!
capacity checks will take place this year... there's technology coming out the a hole this year with the tyre data-dotting, fuel testing and volumetric measurement stuff!
no glenny you say, maybe you boys should just have some patience...
brap brap
dane - rx7 has been pushed to the side for a little bit, but should be running within four weeks though... busy getting the evo ready for tt as a guy wants to borrow and run it!
snowy - commos are so twp, its all about shiney new things for tt!
sav_man - there is some special tool that measures air volume, not sure how it works, but far from the crude screwdriver with a pen mark method seen at some events.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
