Well I just found out today that I can't make either Lake Mountain or Targa Tas this year due to work commitments.
So I'm thrilled to have spent all that $$$ on my car especially to do them now!
:cheers:
We're out of Lake Mountain due to my chauffeur having to attend a wedding on the Saturday :)
So...I'll do the tour instead for sh1ts and giggles. :sick:
Lowth is doing the tour in his new toy again with a couple of other guys as well. I might try and do the same if I can make it up for any time at all that weekend. But I know I'm going to have a consultant over from The Netherlands during that time and at 950Euro/Day I'm going to be needing to get my monies worth for his time!
Cheers Tim. Is that for Targa or Lake Mountain?
Dan: Lake Mountain mate. I sent Helen an email yesterday but have not heard back as yet. :P
Whoops Targa I meant, spoke to my sister recently who works at Wrest Point and she said it was filling up (was full for TWP), and Strahan is usually booked out by now.
So thats general info for anyone out there now :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
