Here is the second last run up. rear tyres had totally delaminated from abuse, I could literally pull long trips of rubber off them exposing the canvas.
was very loose in the bum, and had a couple of little moments, mostly later in the stage. One at 2:40 was particularly memorable, because it could easily have been a sheer drop or a Gum, yet Tim the loon was giggling. haha
Anyway, here tis;
And the Prologue, a Commodore had left an epic oil down toward the end.
Dad and I did it once. Writing them down is the easy bit, the typing them up afterwoulds is shit. I have been thinking about doing my own for next year...just depends how didicated the nav is.
In other news Dad is looking at moving to a new STI Spec-C cause he thinks it will be cheaper....I told him to get prices for gearboxes, engines, and turbos first. And i don't think he'll like running 250rwkw instead of 370rwkw
yes that's what i think too, but Dad think's the Spec-C will be heaps cheaper. But we all know the gtst is the only cheap car :thumbsup:
RB20 sounds gooood reverberating off the walls. were you running the soft compound? or did the motorkana stuff kill the tyres?
Well part of the deal I've made is that car doesn't come with an engine, brakes, shocks, wheels, exhaust or interior. (and tail lights - that car has LED's which I don't want!)
So I'm going to need those parts from the old car as a minimum. The big issue with the other parts on my old car is the bonnet and guards. It will probably run externally as a standard white car for THC but for TT11 I will put the kit back on and then it will be a case of whether the car stays white or goes back to blue. I'm pretty sure I know which way it will go......
But yeah Dan I am keeping the drivetrain in the new one. Anyone want to buy a 5 speed GTR gearbox?? :)
I think Tony has the epic shits re no presentation or mention of the series win for showroom category at the Tugga dinner.
I would too! lol
The Tugga guys need to get someone to write them a list of whom needs to be presented with what and when, and then tick the boxes!.... :)
Well then we can be SURE we won't see him in Early Modern if recognition of results is his thing. LOL
ohhh, I think the exclusion of EM coverage post event may have had something to do with the controversy surrounding it not being ideal :)
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
