Since there'll be bikes at TT 2011, how long before we can expect to be able to run a SuperKart with GPS Co-Driver/Navigator in the full event?
I reckon it could be the hot ticket for an outright, good value too.
So Stu - I see there is no Rookie Rally listed on the Targa Application page for 2011. Not running it next year?
It's so I can't be coaxed into someones silly seat for the third year running!
Happy to leave Rookie behind :D
Haha - its like if someone was brave enough to enter in one of these things.
In 03 some boys ran a Chaterbox... spent every day wet to the ass or pulling it out of a fence. lol brave on bothe counts
Congrats to young Timmy for the 2WD outright win at round 2 of the Tas Rally Series
(ok so it's not Tarmac, but he's normally a Tarmac boy so it counts in this thread right?) :banana:
a good effort after scoring a puncture on stage, not to mention surviving some of Burnie's finest weather in the afternoon
oh, and
next time gadget.... :ermm:
(ok so it's not Tarmac, but he's normally a Tarmac boy so it counts in this thread right?) :D
oh, and
next time gadget.... :)
Actually 1st in P2, we lost out in the 2nd heat after a fuse blew on the Engine Management dropping us 6 min's.
We were 6th outright/1st 2wd in the 1st heat. Ended up 5th overall in 2wd. Grr but them the breaks.
It's on like donkey kong for round three then Timmy :blink:
I was going to make a cheeseburger comment Damo but I thought it might have been too soon :down:
You and Jessie seemed to go well, even with all of the misadventures?
Hope you are feeling better?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
