I've had 2 DNF's @ Targa. One was a wheel falling off and the other was a snapped upper control arm. Both were most likely from old tired parts.
I've had other issues in the past with electrics and not at Targa but broken front diffs from launching the car. (So I consequently switched to a Nismo front with the extra set of spider gears for strength)
This year there were also a number of RB26 engine failures. But I think if you make sure your cooling is right, you have a nice baffled sump, and don't get too greedy with power (I run around 330kw's @ wheels) the engines should be ok.
most common downfalls of the 32/33/34 gtr's at targa? (assume the car is relatively well built with bigger brakes, suspension etc etc)
keen to know what fails first.
There's no special requirement over a hard driven track day car, just build and tune the car with the fact that it needs to keep going without fail for 5 and a half days of competition.
So, the biggest issue is the RB26, you must keep them cool, we've found they last much longer if they run cool, 78-80 degrees, and yes, keep the power to around a genuine 330AWKW. All the obvious oil control issues need to be taken care of too.
Coils are also a constant concern, fresh ones help alleviate any concerns.
Chassis wise, make sure your wheel bearings are good, brake knock off is a serios consideration on rough roads with big rotors, and springs behind the caliper pistons are required to help eliminate it. Otherwise as you know the driveltrain is strong.
A solid sump gaurd is also something I'd recommend.
Greg Garwood is looking for a good tarmac prepped R32 GTR if anyone knows of one?
Yes, I've told him about Jurgenson's and I'm sure he'll follow that up. - edit - Drew doesn't wish to sell now.
Well he is today, who knows what he'll want tomorrow.
The Nav's are the best to answer that....but I'm willing to bet a good GPS should replace the olde fashioned tripe computers....
Yeah I ditched the the terratrip in favor of one of these. It did the trick ok but still not perfect - someone will come out with a good proper GPS based one in the future I'm sure.
IMO, an accurate distance meter is still worthwhile, for times when you come across a car and need to report an acurate distance into the stage for that, or if you have hazards reported on stage, especially if there's multiple hazards. Yes, I know most of us write them onto the notes using the note's distance graduations as a guide when they're reported at the start line, but it's still nice to have an accurate distance to confirm.
I guess someone could confirm all the features of the GPS thingy that was provided at Targa....but I thought one of the features was GPS location of offs.
Extremely good idea i think
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
