I'm a first car owner (bought a 4 door R33 GTS25t about a month ago) so I don't really know what to look for.
Can anyone recommend a honest & fair workshop that's well informed about skylines?
I live in Subiaco, so relatively close to that is preferable but not necessary. So if anyone has one in mind that they highly recommend but isn't near by, I'd still like to know.
Also, I'm thinking it's time for an oil change and it looks like Mobil1 5w50 is my best bet, but I can't seem to find any at petrol stations. Where is the best place to look?
Thanks in advance.
Hyperdrive NOR, about 15mins from Subiaco; they serviced my r33 for about 3 years, always good service and good quality work; the only reason why they don;t do it anymore is because i do it myself now
you can get mobil 1 from any auto-one or similar place
Edited by [Michael]
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
