ECUTalk Consult LCD V2 Displays
2005 prototype showing blue screen (4MB) - just happens this video from very first prototype, uses the blue LCD available for this display. Note the blue screen isnt as visible in competing light than green, keep that in mind when deciding which LCD to get. Although that was prototype from 3 years ago, the main sensor display is similar (instead of ECO:xxx its xx.xL/100KM). Also the update speed there i think is about half the speed of the current one.
Following on from the previous V1 thread, I've almost completed V2 displays that improve on the V1 displays in quite a few areas (can be seen in the 'changes in v2' section on the website). One key change is user updatable firmware (like adsl modem or computer bios), so when I add new features (perhaps logging to microsd card, audible alerts with the buzzer, etc) you will be able to upgrade your display to get the new features.
The display is plug and play into the consult port and requires no wiring (so its portable also). Your consult port is located near or attached to your driver's side incabin fusebox. You will need a car that:
a) supports consult (mostly evidenced by the consult plug near your fuse box, few late model Patrol etc will have port but not support consult for ECU), and
b) still retains the stock ECU (piggybacks and remaps generally fine, but PowerFC etc wont work), and
c) doesnt have messed up wiring to consult port (shouldnt, unless you have an engine transplant or some other reason the wiring may have been messed with)
For Skylines, this is the R32's (10/89+), R33, R34. If for whatever reason the display doesnt work for your car, if its returned in original condition you can get a full refund (minus postage).
Display Hardware:
The unit is 144mm wide, 48mm high, and 33mm deep (buttons protrude 3mm), and weighs ~250g. It is smaller than DIN size (180x50mm) and as such could be mounted in the DIN slot, amongst other places. It has a USB port for the integrated consult interface (accessed via the menu) for those who want to use it with normal consult programs on their PC, and for firmware upgrades.
The unit has 2 buttons on the front (they will be black, rather than the red/white ones in picture), a menu/enter button (the left one) and a cursor button (the right). The buttons are used to navigate through menus and the different features of the device. The menu/enter button initiates the menu (from the main display screen) or selects the currently selected item from any other menus/screens. The cursor button control the position of the cursor mainly in any of the menus, and switches between the sensor display or trip meter screen on the main display. It should be pretty easy to work it out when you use it.
The screen is a 20x4 backlit screen, wide temperate (-20 to +70 operating, -30 to +80 storage), available in standard green, or white on blue ($5 extra). The cable can exit the right or the rear, so it can be flush mounted either way.
Display Features:
  • Trip meter: Shows current speed (kmh or mph), current fuel economy (L/100KM or MPG), and for the current trip: fuel economy, fuel used (L or G), fuel rate (e.g. LPH, litres per hour, or GPH), distance travelled (KMs or Miles), and time elapsed.
  • Sensor Display: Shows current speed (kmh or mph), rpm, battery voltage, current fuel economy (L/100KM or MPG), injector duty cycle (%, and both if car has 2 injector banks), ignition timing, AAC, O2 (both if car has 2), water temperature (C or F), AFM (both if car has 2) and TPS (volts or %)
  • Fault Codes: Displays any current fault codes, along with how many starts since the fault code last occurred. Allows fault codes to be cleared.
  • USBIF: Enables the USB consult interface. Also shows the amount of bytes received/transferred from/to the PC and the last 4 bytes sent/received for some excitement.
  • Max Values: highest values recorded for speed, rpm, water temp, injector duty cycle, TPS, AFM, ignition timing. Allows the max values to be cleared also. Max values are for current trip only.
  • Time Trials: allows you to enter time trial mode, where it will record time from 0 to 60, 100, 160, or record from 0kmh until you travel 400m (i.e. quarter mile). Of course this is not to be used on public roads. Best times are saved into EEPROM (lost when you update firmware most likely).
  • Info: read some boring stuff about who made the display, and the firmware version.
  • Options: set injector cc size and number of cylinders for fuel/economy readings, set LCD brightness/contrast, setup TPS% min/max, KM or Miles, C or F, TPS volts or %, and allows you to reset display for firmware upgrades.
  • (Note: Options->TPS setup): As TPS only uses 0.5v-4.5v range roughly, not full 0-5v, if you set it to % without setting up min/max, it will read ~10-80% from closed to fully open. To setup TPS, you just need to have the TPS like it would be for 0% (foot off) on main sensor display, then go into setup tps and set the 0% point to current TPS value. Then go back to sensor display and go full throttle (ideally car 'on' but not running), then back into setup TPS and set 100% value. Then it should read 0-100%.
Price, Scheduling and Payment:
$200 pickup or +$7 for express postage. Blue screen is $5 extra. $5/unit sold will be donated to SAU. Thought price would go up from V1 displays due to getting more of it assembled elsewhere rather than doing it myself, but this was offset by the higher quantity batch this time, so can keep it a nice even $200 for group buy. Keep in mind USB consult interfaces alone are ~$110, so for less than double that you're getting the integrated usb interface + display itself.
Estimated availability is in August. I'm currently waiting on enclosure manufacture before displays can be sold. Initial run will be around 90 displays split between SAU, PGA and people who have contacted me via the website. If all 90 sell then ill aim to get another batch done.
Payments will only be asked for when ive confirmed that a device is available for you. Payment is via bank transfer (St George, arrives day after at earliest), or Paypal (instant, but has an additional fee of $6 unfortunately). Paypal is only an advantage when bank transfer is inconvenient, or you want the device ASAP (eg its 8pm and bank transfer wont be processed till the next day, and arrive in my account the day after that). You dont need a paypal account necessarily to use paypal, just a credit card.
Pickup is from Blacktown, Western Sydney, or possibly near Wynyard in Sydney (I work there a couple days/week).
I want one, what do I do now?:
Send me a PM stating your LCD preference (green/blue, only indicative for ordering purposes, you make final decision when you pay), and a contact email address (for backup purposes, also for notifications of firmware updates etc later on). I will then add you to the list (see second post). Displays will be allocated to people in the order they have express interest and have subsequently been added to the list of interested people.
As I make the displays, I'll ask the people in the list via PM in turn if they still want one, and if so, request payment. If they can provide payment within a reasonable time, they can purchase it then and pickup/get it posted. Otherwise, they'll either be removed from the list or put to the end of it, depending on whether theyre no longer interested, or just cant pay right now.
Things ill ask for when I've got displays ready and you're next on list:
1) Your full name
2) Your address and phone number
3) Email address (if one hasnt been provided already...for firmware updates in future)
4) Your payment method (bank transfer, paypal (+$6 fee), or pickup). Bank/paypal details will be provided at this time.
Peter
https://www.sau.com.au/forums/topic/228314-ecutalk-consult-lcd-v2-displays/
  • Replies 82
Posted Images
Interest List
please refer to this link (and search for your username) to see your position on list. cant put the list in this thread as we cant edit posts anymore.
Hey Peter,
I have found that i have a consult port and i am still highly interested in this but i recently had an engine swap (same engine). How can i possibly test if the
consult port is working. I have a basic electronic skills and can test for power via a multimeter. Could you help me out on this before i purchase one of
these!
Cheers
-Min
http://www.ecutalk.com/images/consult_car.jpg
confirm ground is connected to ground, 12v gets 12v when ignition on (or car running), forget chk/check (not used), and the remaining 3 should be short circuit/low resistance with their respective pins on the ECU itself (grab a ecu pinout...pins are nearly always around the bolt/middle of ecu pins)
but if you cant be bothered, if the display doesnt work for whatever reason and its returned in original condition in a reasonable timeframe (e.g. a week or two), then you can get a full refund (minus postage).
worst case you can probably chop off ur consult port and re-wire it at the ECU...i did that for RB25DET silvia i had 3-4 years ago.
is there any chance that this will ever work with a power fc?
never, nissan would have patented it probably, so if apexi implemented the same thing they would have been sued probably. even if they didnt, apexi didnt implement consult capabilities so thats all that matters.
ahh i see, i thought this thing was taking raw data from the sensors at the ecu and then it goes from there, but i now assume that everything is done in the ecu and this is just a display.
yep, its plug and play into consult port (which connects to ecu), no wiring or other messing around. so it has the potential to do anything that can be done via consult
when my new engine is done i will go with the power fc purely because i already have it and need to save a bit of money but i will probably change to a dr drift remap so i might grab one then.
Thanks Peter. I guess if it is not connected i can just re wire it into the ecu.
Cheers
-Min
they were supposed to ship the enclosures on thursday but havent heard from them yet. hopefully they ship by sometime next week so i get them sometime the following week.
heard back from them, were delayed due to people taking vacations or something...they didnt give an updated ETA but id hope ill have them by august 9/10 weekend.
here are some pics of the blue screen. first one is better quality but the blueness in the screen is a bit washed out (i.e. it doesnt actually look that way). the second shows the blue aspect of the screen better (but was taken at night without flash so picture quality itself is worse). also shows the black buttons which will be used rather than the red/white ones.
That looks awesome.........!!! Black buttons make a difference too. I still cant wait for it. Any chance i can get one earlier :down: if i pay now *ahem* :P
Also have you ever thought of like a rubber grommet for the USB port at the front? I can just see lots of dust and crap getting in there over time.
no chance :cool:
good news is they have shipped and i might get them monday! and ive taken mon-wed off work to get some of the final assembly done so hopefully not long now!
i did have a look before for grommet, but didnt know what to search for. found a bit more today, like this:
http://www.l-com.com/item.aspx?id=8134
http://www.amphenolcanada.com/ProductSearc...MUSB2D11004.pdf
    • I did end up getting it sorted, as GTSBoy said, there was a corroded connection and wire that needed to be replaced. I ended up taking out the light assembly, giving everything a good clean and re-soldered the old joints, and it came out good.
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
