i heard good things about alpha dog...gotta try and cath it when they show it on cable again...
good thing about JT is his association with Jessica Biel...
bad thing about JT is his association with Timbaland...can't STAND Timbaland...!!!!
lol love guru was fuukn funny! he did brilliantly on alpha dog aswell, i met the guy when he came to perth, as i worked at brass monkey, he came in and got maggot off pure blondes!! (wat a champ) in the main bar where iwas working, nice guy even gave me and 2 other staff members backstage passes to his concert, which was f*kn awesome!!
got too hang with his entourage but not really him as he was too busy concentrating on the stage...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
