I hope you guys don't mind another "which suspension should i get" topic.
I want to replace the crappy worn out stock suspension on my R32 with some good height adjustable coilovers. They need to be adjustable to at least stock height (anything lower than stock height is not good for the bodykit). I basically need something good, but not too fancy (I dont want to spend over $5k). What are your recommendations?
The budget is lets say up to $1500 although I wouldnt mind something cheaper.
https://www.sau.com.au/forums/topic/228726-which-coilovers-for-r32-gts-t/
TEIN FLEX if you can find a set
I had a set in my R32 and they were awesome with plenty of adjustment as well
2 way height, 16 point damper
yea... these sort of exceed my $1500 budget + I cant find them anywhere.
K-Sport or D2s should do the job. they can go pretty low aswell and are qquite reasonably priced
D2s are quite cheap... around $1000 if I remember correctly, but I've only heard bad things about them.
If you are going to go cheap, then go HSD. I have been in a few cars runnig them and they are not too bad, and they are new, locally available and height adjustable
mm, dont really see the point though, the tein basics costs about the same, if not a bit cheaper, its a much better quality product, including the damper. the only reason the tein is cheaper is it doesnt have the damper adjustment, and to be quite honest, damper adjustment on the HSD's is just about useless, even if the HSD's had anything resembling decent damper adjustment, the people that own them wouldnt have the first clue on how to use the adjustment properly.
I've been to Car Toys (import part store in adelaide) today and they have GReddy Type-S for R32 in stock for around $1770. Is cca $200 over my budget, but technically I dont have any budget anyway coz I'm putting it on my credit card... + they have interest free available so I may not have to use credit card. I've heard they are pretty good and $1770 is pretty good price... usually they cost over $2000. What do you think.
Are there any other good places in adelaide that sell suspension I should see? I had no luck finding TEIN flex for $1500.
Edited by Rocky88
what do u use ur car for?
Daily commuting and just driving around for fun, often in hills and country. I dont use it for track racing but i still want good height adjustable coilovers. The stock suspension I have on currently is already its on death bed so i need something new quickly.
if its a daily commuter, wouldnt it make sense to go for a more street setup? u can still have fun in a car with softer spring rates, on the street u wont notice as much difference as the car is not being put under the same load, even pushing the car through the hills. so let me ask u this, is a tiny amount of speed through the hills once a week or so worth putting up with a much worse ride comfort for the rest of the week?
There is this widely held belief that in order for a car to handle well it HAS to ride harshly. Which is of course complete and utter rubbish. The truth is you CAN have a car that rides acceptably and at the same time handles very well. You just have to choose the right components and then set the suspension geometry to maintain the maximum tyre contact. After all, keeping the tyre in contact with the road surface at all times under all conditions is what makes a good handling car. A car that leaps from bump to bump is hardly going to handle very well, because it has no grip when the tyre is off the ground.
Cheers
Gary
Yea, good point, although spring rates can be adjusted on coilovers. The reason why I considered greddy coils is because my choices are 1. very cheap coils like D2 (cca $1000), which according many people wont last long even if just used for daily commuting, then 2. good quality basic street coilovers like TEIN super street, which cost around $1500 (apparently I could get them for less, but god knows where) and then for a little more Greddy S-type.
Besides S-type is (according to their website) designed for comfortable ride:
Designed for the optimum balance of traction, comfort
Instead of the common heavy spring rates, that offer harsh rides and easily loose traction on bumpy American roads, Type-S systems utilize a relatively softer spring with a longer stroke to maximize traction on the streets and track. An added benefit of this is also a comfortable ride for the street.
Edited by Rocky88
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
