Does anyone here know how to fix the clock in an r32 gtr. Apparently its very common and that most r32 gtr owners
have the same problem. Is it the fuse under the left hand side of the steering column maybe needs changing or does it have a fuse in the fuse box? Im sure someone out there knows or has fixed it!
Thanx Guys!
https://www.sau.com.au/forums/topic/228835-clock-in-r32-gtr/
If you've got an aftermarket stereo, there's a good chance whoever installed it just wired it straight to the battery with an in-line fuse. Just check none of the blade fuses are blown first before you do anything else.
  • 2 years later...
Very common issue. Normally isn't a fuse either. Auto Sparky quoted me $180 to fix it (they apparently have to take the dash apart)
The clocks in a hard to see position anyway
nope. not in a hard spot really at all.
take the cover off that if your in your drivers seat covers from about your shins to your knees (6 screws from memory but don't get caught because one is on the side of the dash that faces the drivers door) and lay with your head at the pedals and feet hanging out the door. (move the seat back as far as it'll go and steerig wheel up as high as it goes) and you'll see the back of the clock with 1 plug in it and 2 screws.
undo the screws, slide the whole thing out and undo the plug when you're sitting out in the driver seat (has a fair bit of slack)
there are 4 dry solder joins under the clock screen on 30 ohm resistors and these are the common problem. takes about 15 minutes to get it out if you have no clue what you're doing but i strongly strongly suggest you take it to an electronics shop to get the clock screen removed and the the soldering done as the screen is unbelievably easy to break and then you are screwed. (about $350 to buy a new clock from nissan) seriously thinking about doing it my self though. got the clock out about 10 minutes ago and looking at it now. don't think i'll risk it though , i'll be good. :)
if you live near flagstaff hill sa i'll help you get the clock out. take me about 20 minutes to get it out and have all the dash back in for driving till you want the clock back in.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
