  • Replies 144
from earlier in the thread:
sorry bud, stock steering wheel is pretty ordinary condition
by that i mean f**king disgraceful
Matt,
The ball joints are after market roll center adjuster type ones. I don't think they suit a gts4 hub anyway. I have no idea if the rack is compatible but if you can confirm it is then i still have it here.
Update:
s1 rb25det, no coils, no turbo no injectors. sump has a dent in it where it hit the sway bar but can provide a spare, runs well, good compression $1350
GTR front drivers side guard with lip rolled and a small dent above the wheel arch, silver, $200
GTR front drivers side indicator $100
GTSt front guards with compliance indicators, pair $300
rb25 ignitor $125
rb25 clutch slave $50
And the after market bits
Just jap B pillar brace $100
Maltech braided brake lines ADR compliant $250
early model hks rb25det cams 256 8.8/264 9.0 inc adjustable exhaust wheel $650.
plus a heap of random crap thats still got to be pulled out of the shell
  • 6 months later...
i still have the pedals, master and slave cylinder and the lines. send me a pm if you are interested
I've been meaning to start a new thread since i can't access my old acct any more...
cheers
Dave
  • 1 month later...
I bent my r32gtst yesterday so i am parting out the salvageable bits of the shell and misc bits and pieces of trims and panels. I also have a few aftermarket bits and pieces and the rb25det and box.
The aftermarket parts listed are all i am offering on that front but obviously i am not listing all of the available stock parts from the wreck so please ask if it's not listed.
If you are interested in something but need more details please pm or post as i am keeping this ad brief due to the number of parts.
I'm negotiable on prices to a certain extent but low ball offers will be ignored.
Almost all parts are still on the car. I would prefer to sell the engine before removing the pfc, coils and looms so that prospective buyers can see it run before removal from the car. After that goes it can be a free for all. I will remove listed parts from sale if i find that they are damaged when i start dismantling. I have not listed any parts that i know are damaged (like radiator, intercooler, z32 afm or power steering pump)
r33 S1 RB25DET long motor with extras inc HKS 256/264 cams and adjustable exhaust cam gear. No turbo, coils or injectors on engine but a rail and 6 stock injectors will be provided separately $2000. Includes all sensors but no looms or alternator/power steering pump/AC compressor.
6x550 side feed blitz injectors in rb25 rail $500
r33 rb25det Power fc inc hand controller $1000
r33 S1 RB25DET gearbox with custom 1 piece tail shaft suit r32, modified GTR speedo drive, slave cylinder and modded cross member $1850
rb25 det engine loom modded to suit late r32gtst manual. Minor changes will be needed to suit stock afm (4 wires) and o2 sensor(3 wires). currently wired to suit z32AFM $250
GTSt indicators, pair $150
rb25 ignitor $125
rb20/25 CAS $100
Trust remote mount oil cooler $500
Xtreme XHD 9 puck clutch kit $500
Cusco comp coilovers damperand height adjustable front and rear 8/6 $850
Cusco master cylinder brace suit 32gtst/gtr $90
Whiteline 24mm front sway bar $180
rb20/26/s1rb25 splitfires $400
Trust type R bov $200
Cusco castor rods $150
Just Jap adjustable front upper control arms $250
Stock front upper arms with nolathane adjustable bushes $150
2 Davies craig 14inch thermos $100 ea. I'll throw in the controller if you buy both.
I can probably pull together the parts for a 32gtst manual conversion (minus box, clutch and flywheel) for $150 or so. Master and slave less than 3 years old.
I have the full interior in reasonable condition except the drivers seat and the carpets a bit rooted.
misc bits and pieces like rb20 and 25 alternators (1 each) rb20 and 25 AC compressors (1 each) rb25 starter motor, various AC lines, full boot trim, etc etc
Most panels rear of the A pillar are ok, though the passenger side door would need repairs to the leading edge.
Thats about all i can think of.
Front brakes, diff, rear arms, rear brakes and rear swaybar are not for sale.
cheers
Dave
after rear quater glass surrounds on both sides please
  • 1 month later...
hey mate, i tried to send you a pm, but i was wondering if you still had the rb25 starter motor?
G'day. I saw that your car was non abs. I am after the hard brake lines that go from the master cylinder back to the junction box going to the rear, the line that goes to the left wheel arch and the one that goes to the right wheel arch. Would $30 collect do? Thanks, Ben.
I can do the line that runs to the junction box. the fronts were cut during stripping of the car. Personally i wouldn't use the line as it's been open to the weather for 6 months and is corroded.
gday, im after the instrument cluster? can i pls get price, kms & suburb to collect pls? cheers/martin
Sorry, dont have a complete one
hey mate do you have a stock front bar at all???
tried to pm but no luck
cheers
It got destroyed in the acco
keen to sell the clutch master and slave cylinder on it own mate?
PM me either way cheers
Yep, happy to as i chopped the stock lines the other day when tidying up as i couldn't be stuffed storing the whole thing. sending pm now
cheers
Dave
rb25 ignitor $125
rb20/25 CAS $100
cheers
Dave
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
