Hi Everyone,
Just need a little technical support, my GTR is running the standard airbox with a K&N filter. My mechanic is telling me to go for some pods and get rid of the factory airbox.
My car already has an HKS drag intercooler and 3.5 inch exhaust from the turbo. I have been told that the only thing letting the car down is its breathing ability and that I should expect a noticable difference.
Any advice would be greatly appreciated
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/
If u do make sure you build some type of cold air intake (see: forced induction area), otherwise you're just going to be sucking in warm air which may give you worse performance.
Some argue pods are a waste of time compared to a good panel filter, but they sound better :(
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491283
Originally posted by Canadian GTR
Leewah
Did any of those GTR's have any mods to their standard airbox,
extra cold air feeds running into their standard box or airflow meters??
No. Because of the way the airbox feeds from the front of the bonnet anyway, it was cold air already feeding to the turbos.
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491337
Leewah,
I guess what I'm trying to find out is if the standard box provides enough air to the turbos given the mods I have, or would an additional air supply be benificial, say for example if I added another cold air feed from the front bar into the standard box.
Or would that be over kill ??
Cheers
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491402
There is no real such thing as overkill when it comes to feeding the turbo cold air. What you need to try to accomplish is giving the turbo as much air as possible as long as the air is cold and directed in a straight line. Turbulant airflow has a very negative effect on the effectivness on a turbo. We found a 4 rwkw loss by simply removing the air pod. We found that the air pod directed airflow in a less turbulant direction so we left it on.
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491453
hehe all i can say is if u slap on that pod go get an engeneers certificate for it or when u get pulled over the nice little men in blue will be putting a nice little yellow sticker on your windscreen, and acting as if there mechanics when there telling you to put back your origanal air filter lol :) good luck mate you got to weigh up the for and against mate but id put one on anyway :D
and if your going to do it do it proply with the right filter dont get some REPCO $5 filter just to save money get quality stuff its enhances the performances and last longer as they say you get what you pay for
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491772
I think I will leave the box standard and try to feed it more air through the front bar.
If anyone had done/tried this on a GTR I would love to know !
Thanks for the help
I know a couple people both in GTRs who run a standard airbox and his best time so far is 11.4@124MPH
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491942
Thanks everyone,
Thats the great thing about these forums you can chat with people who have been there and done it rather then taking the advise of a mechanic who wants to make more money !!
I'm going to stick with the standard box and get my hands on some cam gears next !!
I will probably need some more help when I get closer to buying them.
Cheers
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-492974
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
