have paid money into adrians account, should be cleared or there by tomoro arvo or friday!
have updated my order in the pm DAMO_R34 do i need to add it on this thread aswell or is it alright as is?
Edited by Jonnyboy89
  • Replies 665
Posted Images
hoodie/jacket: Jacket
user name/real name: Allan
name in caps or not: "As Above"
colour: Black
how many: 1
ill make my payment next week rad33 if thats ok
pm me back thanks for place to meet for payment etc.
cheers
Allan
Jonny, i have sent your order to Adrian, so don't worry about posting it in here.
Edited by Damo_R34
hoodie/jacket: hoodie
username/real name: no name
name in caps or not: -
colour: black
how many: 1
username/real name: SCOTT
name in caps or not: caps
colour: black
how many: 1
username/real name: InH3aven32
name in caps or not: like above
colour: black
how many: 1
username/real name: Fabs
name in caps or not: As Above
colour: Black
how many: 1
hoodie/jacket: Hoodie
username/real name: -
colour: Black
how many: 1
Should be there at villi's tomorrow night.
P.S. Cruise after anyone?? :blink:
