  • Replies 665
Posted Images
ps... im not gonna go chasing up who havent paid!!
if i dont have cash u miss out! bad luck! u have had 2 weeks!
any problems let me know!
thanks!
now to trader rate everyone hahahahah
oooooh do me! I was super efficiant n shit :banana:
you want a top looking T-shirt you will have to ask Jess aka >>Sinful<< about this
:ermm: I love sau apparel...
It's like that new car smell... thanks to air freshners, they can re-live that smell for old cars, too!!
Talking about air freshners, I found one the other day at Sprint which was a Leather air freshner... yes, you too can have your car smelling like real, authentic, fresh... LEATHER!!
And I know Airwick used to have a Tobacco air freshner... so your house could smell like Tobacco all the time!!!
/backontopic
oh awesome. Anyone know a rough ETA? The second one I got is for my mates bday, which is tomorrow... I already told him it's gunna be late, but I also said he's lucky to get anything at all, so no biggy, just want to know when you guys need a shipping address :)
