Hey all, just purchased a carbon fibre air box from topstage which look awesome. Trial fitted it last night and found that it doesn't provide room for anthing to get past it so essentially enclosing everything (yes duh, its an enclosure). Now my boost controller is mounted right next to my pod and with this setup installed will be pushing the hoses against the side of the car, therefore cutting off the boost. Long story short, can i make i small half circle in the edge of the the box without causing damage to strength, etc of the air box?
https://www.sau.com.au/forums/topic/229148-cutting-carbon-fibre/
Use a dremel.. Use a sanding head (the ones made from stone material) and cut away what needs to be.. Use masking tape to cover the parts surrounding so it wont shatter the cover coat.
its that easy :D
You can also use a drill, tape the drill button to on.. lock it in a vice and use it like a lave.
Use a die grinder or dremel with a small cutting disc works a treat. If you rough cut it first then go over with a sanding barrel it will come out fine, I've done countless times and never a issue once. Just use high rpm's when cutting and all will work out good luck mate.
diamond cutter is the easiest way of cutting CF. i work with it day in and day out, also would be highly recommended to have some 1 hold a vaccum cleaner nearby to suck up dust. its harmful to the lungs.
+1 about the WARNING of inhaling this stuff!
If you can't work on this outside, wear a mask, place electric fans to draw dust away from work area (ie facing the front of garage or workshop door). And vacuum up later. Either that, or as per above, place the vacuum suction somewhere close as you're doing it. This way, the fibres won't bite you back decades later.
Cheers, T
Cheers, T
Will do. Thanks again for all your help guys :P
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
