Hey all, just purchased a carbon fibre air box from topstage which look awesome. Trial fitted it last night and found that it doesn't provide room for anthing to get past it so essentially enclosing everything (yes duh, its an enclosure). Now my boost controller is mounted right next to my pod and with this setup installed will be pushing the hoses against the side of the car, therefore cutting off the boost. Long story short, can i make i small half circle in the edge of the the box without causing damage to strength, etc of the air box?
https://www.sau.com.au/forums/topic/229148-cutting-carbon-fibre/
Use a dremel.. Use a sanding head (the ones made from stone material) and cut away what needs to be.. Use masking tape to cover the parts surrounding so it wont shatter the cover coat.
its that easy :D
You can also use a drill, tape the drill button to on.. lock it in a vice and use it like a lave.
Use a die grinder or dremel with a small cutting disc works a treat. If you rough cut it first then go over with a sanding barrel it will come out fine, I've done countless times and never a issue once. Just use high rpm's when cutting and all will work out good luck mate.
diamond cutter is the easiest way of cutting CF. i work with it day in and day out, also would be highly recommended to have some 1 hold a vaccum cleaner nearby to suck up dust. its harmful to the lungs.
+1 about the WARNING of inhaling this stuff!
If you can't work on this outside, wear a mask, place electric fans to draw dust away from work area (ie facing the front of garage or workshop door). And vacuum up later. Either that, or as per above, place the vacuum suction somewhere close as you're doing it. This way, the fibres won't bite you back decades later.
Cheers, T
Cheers, T
Will do. Thanks again for all your help guys :P
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
