  • Replies 239
Posted Images
Yeah, well I spoke to the blokes with the TommyK and the Nur:II. The Nur was a NurNOT as it was just badges put on a V-SpecII. The TommyK was real though. All the detail on it was amazing! It is too bad that they can't save the foot mashing for the track. Agreed, most of us can do a big burn out too - so what is the point.
When I told them I save the tyre spinning for the track in GD2ILA and they couldn't believe me. What's the point if you loose your license or worse if the police use the hoon law to take your car for 3 months!
I had a really good time! Thankyou everyone!
Cant wait for the next one! =)
yey!
Anna had fun, thats all it matters :ninja:
:P
hey guys what happened to Albert??
Didnt he go on the cruise???
Nuh man lol, my head was loose from the night before.
yes yes but also remeber i really doubt highway patrol would get close enough to see their number plates lol
Mate, I know you're probably joking but just remember it's a public forum.
Well said Pezhead, no need for it on the streets, yes they were nice cars but hell we all have nice cars and the majority can control their right foot as proven by the guy with the white R34 GTR who left after them. That Tommy Kiara car was very nice, I didn't think the other was a Nur Spec, if you want to see one of them, when I'm back on the Thursday cruises I'll ask my friend to bring his Nur Spec II down :huh:
I didn't see a Nur spec? Also the blue R34 GTR leaving, as good as it may sound isn't really the image that we want for the club. Any of us could it, we just choose not to.
Maybe so any of u could do it. But 99% of u wont.
Hey each to their own. Thats how i see it.
PezHead-It is too bad that they can't save the foot mashing for the track. Agreed, most of us can do a big burn out too - so what is the point.
I dont think most of u guys can make a R34 GTR spin in a controlled way.
So yeah Eric. Anyways nice R33, maybe next time there is a Track Day can u invite me.
Thanks
Edited by GTR32X
hey guys, it was a good meet as this is my 2nd time. Sorry i couldnt stay and curize with you guys, i was too tired to do any more driving.
Im the owner of the white R34 GTR, just to confirm is a vspec II, not a Nur? i have no idea why it was bought up as a NUR. Im just glad i have a GTR..... lol
GTR32X, your car is sexual, evertime ive seen your car, theres always new goodies on it and same goes with the Grey GTR.
Thanks bro u too
the RE30 looks good on u car!!
They are talking about Moeys car, Cause he has a V-Spec2 NUR badge on the back of his car, and it isnt a NUR
But anyways u hear the Blue R34 GTR leave??
I think it sounded nice and spun nice LOL!!!!
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
