Hi,
Ever since I have had my car (4 months), I have noticed it behaves differently as the level of the tank changes. Around half way, it seems to run rich (sluggish) and goes through the fuel FAST. When almost full and getting low, the car seems to run leaner and respond well to boost and spools up quickly, responsive and alive?
It's an r33 skyline S1 by the way.
What could it be?
https://www.sau.com.au/forums/topic/229355-half-a-tank-sluggish/
Think I might go with something like a Tomei Fuel Pump - 255L/H for skyline. Do I need a tune after the new pump is installed if using the same regulator?
Thanks.
How exactly do you tune a fuel pump? If you install a large fuel pump with stock injectors, there are gonna be issues as the pump wull not fully be filled before going to your injectors. I may be wrong.
Yeah could be mate, I'd replace it to be safe.
Mine went without warning, My R33 s1 wouldn't start at Autoone one day, so I tapped the bottom of the tank to get her started and speed home. $180 for a walbro 400hp ( I think thats the brand?) and 30 minutes to install it myself.
They are piss easy to replace. Theres a guide on here somewhere.
I wouldn't waste my money on a brand like that. It just pumps fuel. A bosch 040 or 044 would do the trick. I only say bosch as it is a proven good brand and not too expensive either. Walbro isn't too bad depending on how much modification you want to do, but I hear they dont last anywhere near as long as a bosch. I am changing mine next week just for safety's sake anyway. Car starts properly and all, but I dont like the weird noise it makes sometimes when it primes.
Cheers.
I get the weird sounds when I am starting my car, and the pump is priming; but - I also getting a raising electronic sound from the pump when slightly lifting the rpm above idle.
Looks like it's time for a new pump.
Where can I find these bosch pumps for a decent price you mention trel?
And what do you mean about 'modifications' with the Walbro - mods to the pump itself or engine wise?. I here the Walbro's are made to operate at 15v? - Does anyone know if the flow will be fine at 12v or does the voltage need to be raised?
Noob question = How can my car get tuned with stock ECU and uprated fuel pump?
From what I'm thinking it can't be done without an aftermarket ECU (eg.Power FC) - Will an SAFC suffice?
Thanks everyone.
Sam.
Thanks everyone.
Sam.
Ok well, bosch pumps can be found anywhere, repco, bursons etc. Try Kudos Motorsports on here he has them pretty cheap.
Modifications with Walbro I mean engine mods, I hear they shit themselves easily. The bosch pumps are best by what I hear.
You can get your car tuned with stock ecu by doing a re-map on it. SAFC is a fuel cut defender. Why do you want an SAFC? Are you getting fuel cut issues with your car?
Hope this answers some of your questions.
Hi mate,
No fuel cut issues with the car at the moment. I think the ecu has been remapped and wiring loom has been modified - posted a thread a while back 'What the hell is this?!'. As per running the stock pump, which I think is going to go soon, I am anticipating a decrease in air: fuel ratio which I think can be resolved using an SAFC to moderately tune the engine due to the increase in pressure with the new pump, due to the fact the car was remapped with a dodgy pump.
How much do the bosch's go for? - I am looking for a direct in-tank replacement.
Thanks.
Sam.
ok there is a DIY on how to install the bosch 040. They are a good pump, but i dont know what you lot are complaining about the priming noise. ALL good pumps will make the noise when u turn the key on. My 040 humms all the time, i have done the 14v mod to it too.
Just cause ur fuel pump makes a noise it is in no way stuffed.
EDIT Written by: Choku_Dori
Edited by blck32
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
