The problem with streaking all comes down to what rag/cloth you are using.
Gotta use rags that feel really dry and rough (towels, flannelet etc)
not smooth or soft...
Best method i have found is.....
Use 2 rags, spray glass and wipe with first rag till most of window cleaner gone...doesn't have to be perfect then spray the glass again but a bit less and wipe with second rag until dry and all streaks gone.
the more dry your rags are the better the result
All of the above works but if you want it looking really wicked then let whatever you have used fully dry, then get yourself one of those microfibre dust cloths (got mine in a $2 shop for... $2 :) ) It also works really wicked on your paint work, makes it come up as if you had it cut and polished, everything needs to be completely dry to do it properly. I have one for my windows, one for the paint work and one for the mags :P
very mild soapy water on window tint only I wouldn't trust anyhting else, especially if you don't know what quality tinting film you have..
+1 for newspaper and vinegar...
Although after washing my car I usually stop by the servo and use their paper towels and if your careful you don't get the lint effect...
i use this window cleaning foam and a special square like pillow made for cleaning car windows it is soft but slightly Abrasive after i rub the foam of with it i go over it with a micro fibre cloth. After that they are pretty much crystal.
Oh and i got both products from supercheap auto.
Edited by phenline
phenline i think i have both the products you are talking about! i found the spray worked awsome sometimes and others it streaked really bad...figured i was using to much of it. I may have to try it with a 2nd cloth to wipe at the end and see how i go.
In regards to metho i think it stuffed my rear window tint(old man put it in my washer bottle) the tint likes whiteish from the inside but i noticed it not long after i got the car so i dont know if it was like it when i got it.
is metho bad for window tint?
Metho is a window cleaner, as I read last time.
But I would not use it on your window tint.
I ment clean the outside of the windows with metho don't rub it in on the inside where your tint is.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
