Guys I'm getting back into datsuns so I have some R30 skyline gear just sitting gathering dust.
First up is a set of RSR lowered springs to suit R30 skylines. New never used. Stickers read 'RSR ROAD'. $220 pick up or $250 posted
I have a custom triangular strut brace to Suit HR30. Does not clear FJ20 engines. VGC $150 pick up or $175 posted
Lastly i have a jap 2.75 cat back exhaust which has been cut about a foot from where the muffler connects. Included is a large 'Super Cat' cannon. System came off a DR30 coupe, unsure what mods are needed to suit sedans. $200 pick up only.
PICS COMING!!
Edited by D-limo
are the springs for a coupe?
PICS COMING!!
Pics as promised. Cat included with the zaust. 3 inch inlet. Sounded tuff on mates DR30 sedan, has mount to suit.
Located Sunshine Coast QLD
Can you repost the pics, they aren't showing up.
  • 1 month later...
  • 3 weeks later...
  • 4 months later...
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
