Have had the car for a couple of months now and after about a month is started making this tapping noise when the engine is cold .. the tapping gets faster when you press the gas pedal and it goes away completely after about 5 minutes when the engine warms up.
Took it for an oil change and the mechanic says (car still with them for other issues) it's still making the tapping noise even after the oil change ... so what could it be? He reckons lifters .. but I thought a new oil should fix that up if it's lifters (new oil is 10W40)
could it be anything more serious than the lifters? There's no noise when the engine warms up ..only for the first 5 mins when engine has cooled down. Cheers
https://www.sau.com.au/forums/topic/229786-tapping-noise-when-engine-is-cold/
i bet money its a exaust manifold gaskets . my sons had exactly the same symptons and i was convinced it was a lifter but i was proved wrong it was the manifold gasket due to broken studs.
ticked like crazy when cold and disapeared completly when warm
Hiya D,
Either of posts #2 or #3 could be right.
You've only had the car for 2/12. So did you buy a car with full service history? Meaning were all the services done?
Check for sludge around the oil-fill opening. Hopefully the seller didn't put additives in before the sale to disguise the noise at cold. If so, the noise from valve lifters will come back.
If there's sludge, talk to your mechanic about cleaning it out.
I don't know if the Nulon product for lifter noise is good or how it works; or whether it can lead to sludge residue.
It can also be the gasket which was mentioned above because with heat, the thin gap can disappear through expansion.
Best to change this though if it's the problem eh?
Cheers, T
Its the lifters... Using a higher grade oil say 10-40 or 15 (wouldnt go higher) will stop it.
I must add ive just got this problem and It was due to the car running extremely rich and fouling the oil, thinning it out anyway.. Im actually replacing it today as it was becoming more noticable.
Id also mention your car most likely has not done the recommended KM.
The gasket problem mentioned above does not particularly form as a tapping sound more a hissing sound or squeel.. Just like a fuel pump of course this depends on your particular leak.. tapping could be a lose turbo but its very noticable.
When it all comes down to it.. It could also be your injectors as they do tap .. but I doubt it unless you've upgraded.
My money is on the lifters as its the most common noise complaint with skylines .. Cheers
Edited by DECIM8
well when my sons gasket was gone it was a def tapping noise not a hissing at all thats why i was conviced it was a tapped the noise got quiter as the engine warmed up as the gap got smaller as the manifold expanded ive worked in the motor trade for many yrs and still work part time as a mechanic and this one had me fooled and was glad to be proved wrong . if putting thicker oil in helps then you can rule out the gasket .
but i still stand by my statement that its a fair chance of been the gasket .
cheers mid life crisis
My car just started doing this as well. I've been seaching these forums for the cause of the tapping and I'm convinced its broken exhaust manifold studs (as midlife crisis pointed out). Does anyone know if its safe to just leave the broken studs as is? I'd rather replace the studs and gasket when my turbo dies rather than pay the $500+ in labour just to replace the studs.
Thanks for all the tips .. I'll tell me mechanic to take a look at each. The oil's already been changed to 10W40 and the noise is apparently still there so I'll have em take a look at the manifold gasket next. Cheers
Well, how certain are you that your car has actually done 64k... A genuine 64km car wouldn't have noises like that not for 5 mins at least till its warm. But if you are convinced that it's lifters thicker oil couldn't hurt... All depends on how tight your motor is. A higher K motor will do good on 20/50 but I think its a bit thick.... Will cause you some bad cold start issues. Just start the car and get a screwdriver and use it like a stethoscope see if you can track down if the noise is coming from the rocker cover OR broken studs.
Worse comes to worse a decent mechanic can track it down for you.
Good luck man.
Hey have you checked out that Nulon Valve Lifter additive yet?
And BTW you know already eh, that whilst you might go up from 10W to 15W,
you replace synthetic with synthetic & non with non? If poss. same brand too?
Tell us how it goes...
T
Thanks Terry I'll give that valve lifter additive a go if the mechanic can't find the problem ... Does this stuff have any negative effect on the oil?
EDIT: never mind, found my answer ..seems safe and apparently doesn't affect oil viscosity (http://www.autobarn.com.au/products/10/70/3303550)
Edited by Delta Force
just read in another thread about this lifter additive how it cleaned out all the crap from some poor chap's engine that it started to sound like a tractor due to all the lifters becoming noisy. Might give it a miss then :D
just spoke to mechanic and he said he listened to the engine with a stetoscope (or whatever the spelling) and reckons it's near the cam inside the head .. so most likely the lifters. He said he looked at the manifold gaskets and it wasn't that .. Ah well.
Does anyone know how much it would cost approximately to repair r34 (gtt) lifter(s) incl. parts and labour? I'm just looking for a ballpark figure ..
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
