Have a quick search, 0.8mm isnt really necessary unless running higher than stock boost or if your coil packs are on the way out where the 1.1mm gaps werent giving you a good enough spark due to it being blown out by higher boost etc, if you car is relatively stock to mildly modded you shouldnt require 0.8mm.
1.1mm should be fine but the choice is yours :blink:
Steve
https://www.sau.com.au/forums/topic/230101-spark-plugs/#findComment-4044797
not wanting to hijack a thread, but what diff does splitfire coils make?
Has anyone tried widening their gap again after installing them?? Logic says that if they are better than std coils, then you don't have to close the gap, it can be reset to say 1.1mm.
https://www.sau.com.au/forums/topic/230101-spark-plugs/#findComment-4045702
took my car (r34 gtt) for a service recently incl. spark plugs changed. My car has only only light mods (exhaust and 11psi boost) and it's tuned and not missfiring. However the mechanic insisted the new spark plugs should be 0.75 gap even though my tuner said since the car is not missfiring any new spark plugs shouldn;t be gapped. Any harm in having new spark plugs with a smaller gap anyway ??
https://www.sau.com.au/forums/topic/230101-spark-plugs/#findComment-4046048
No, but I wouldn't go below 0.7mm, try 0.8mm.
Its only for cars running more boost anyway, say +12 psi. if your not running more boost don't do it.
There is a balancing act between boost 'blowing the spark out' and the gap being large enough to provide a healthy enough spark to completely ignite the fuel.
https://www.sau.com.au/forums/topic/230101-spark-plugs/#findComment-4046314
As mentioned, theres no harm, just less power. Exposing the volatile chamber mix to the strongest lick of plasma possible, prevents chamber velocity from effecting it, as well as having the greatest chance of complete charge combustion.
SplitFire allowing larger gap? Not that I've seen... They are simply cheaper then OEM coils... and blue.. so homos buy them. Serious contenders use Twinspark or proper step up amplification
https://www.sau.com.au/forums/topic/230101-spark-plugs/#findComment-4046489
Back atcha, you have a HKS amplifier, or an MSD system. Can you increase the gap back to say std?? Or are you forever limited to the murky depths of 0.8mm.
[btw I agree with you on the splitfire, any perceived improvement in spark is still insufficient to increase gap].
https://www.sau.com.au/forums/topic/230101-spark-plugs/#findComment-4046521
ah .. I think I get what GeeeTR meant now .. 'smaller gap' results in less power (from the ignition coils) needed for the spark to jump accross the gap. I read it as 'smaller gap = less engine power' lol :D
Edited by Delta Force
https://www.sau.com.au/forums/topic/230101-spark-plugs/#findComment-4048086
ah .. I think I get what GeeeTR meant now .. 'smaller gap' results in less power (from the ignition coils) needed for the spark to jump across the gap. I read it as 'smaller gap = less engine power' lol :P
Chuckles, you read correct the first time :blink: but power loss is relative. I was trying to get at a stronger spark getting a little more combustion pressure out of bad (rich/lean) mixtures and rough condition (lots of boost or rpm or N02 or WI)
Ppl saw CDI or other cool multi spark per cycle setups really in big camed, holley'd street V8's first, as large valved heads aren't conducive to good low rpm combustion efficiency, coupled with the afore mentioned generously jetted 4 barrels.
Think of all the twin plug per cyl industrial motors, alfa's, aeroplane's etc. There must be a reason other then maintenance durability me thinks.
Guess you could try tappin some plugs to .10mm and go for a drive :D
I think the gist of the thread is that, most RB's out there should be able to run .80+ minimum, if not theres a sad ignition component somewhere.
Edited by GeeTR
https://www.sau.com.au/forums/topic/230101-spark-plugs/#findComment-4049440
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
