my gtr does this when the front wheels decide to engage,
its like a light constant vibration throughout the whole car,
as i bvack of and teh torque guage reads 0 or less than 10 its fine no vibration at all....
i read some other threads but they came to the conclusion that its the center bearing....
if it was the cb, wouldnt it do it in rear wheel drive???
im yet to do a oil change on the attessa system but will in the next week,
possibly a bent front tailshaft?? or CV issue??? front diff issue??
cheers
denis
cheers
denis
Slipping clutch packs in the transfer case maybe?
Thats the only thing that changes when the fronts engage...or could possibly be the front diff, only when it has load on it its making the vibration, but I highly doubt that one.
Transfers are usually pretty bulletproof though. Plenty of oil in it? Maybe put some fresh stuff in. (Takes ATF)
i know the 4wd light comes on sometimes as i start it, and i havnt bled the system yet as per another thread, so ill give it a go, the clutch packs i doubt are worn as it does do mad 4wd hellies.. in a private industrial area
gday dont mean to hijack but mine does something very similar - only at lows speeds though while sidways (i.e.: skating a roundabout)
i thought it was because the front tyres were hopping on the road as it only happens when the car is really crossed up, is this the same with you?
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
