Hi,
I did a search for dynolicious and couldn't find anything so forgive me if its been mentioned already.
Dynolicious
From the site.
* 0-60 Acceleration
* 1/4 Mile Elapsed Time
* Lateral G's
* Horsepower
If you have an Iphone its a cheap ($15.99) way to see some fairly accurate(?) stats for your car. Just do a search for dynolicious in the app store.
It does not have metric units in it so far, but I think it will be very popular and will get a metric option down the track.
Check out the screenshots page
EDIT: Just playing with the app now, you can put multiple cars into it, you get to put a photo for your car from the camera's photos. You also get to add mods to see before and after results. It has mounting instructions in the app.
The only testing ive been able to do so far is to swing it about to get to to measure g's and things which is making me look like an idiot in the office :blink:
https://www.sau.com.au/forums/topic/230220-dynolicious-iphone-app/
Must work in a simliar way to a g-tech, accuracy will depend on the quality of the accelerometer in the i-phone. And a g-tech is accurate to aboutn 1/10 of a second they say.
Even if it isnt accurate (but it should be ok), it should be consistant, if you get what i mean. So good for comparing before and after. But i dont find the horsepower tool on my g-tech very useful, so i doubt you will on ur iphone.
Very nice little program...you essentially get a basic g-tech for a fraction of the price,
post ur times up
Or if you have a symbian S60 phone you can get that and more by using an ap called race chrono found here --> http://www.racechrono.com/ which is 100% free.
Thanks TiTAN.. hadnt heard of this before..
I have downloaded and installed it with the latest firmware onto my 6110 navigator, and ill let you guys know how it goes once i give it a run..
Hrmm, wonder whether GPS or accelerometer would be more accurate.. And if someone could make one for the iPhone that uses both for accuracy haha.
A 1hz GPS won't be accurate for standing start stuff because it only updates once a second.... a 5hz would be a bit better, a combination of both GPS and accelerometer would be good.
That is gold!! How do you know if your S60 symbian mob has an accelerometer or not, was thinking of getting a samsung G810, not sure if it has one though, would love something like that if it could data map stuff.
Don't worry, just saw it on the list for the 3rd edition... Pays to actually read links
Edited by bluer_32
N95 is S60 with acceleromter
ive got one on mine called TEMPES.GTX
its pretty average. i'm sure racechrono works on N95 too, but it has too many options for my liking.
i'm guessing Dynolicious will be ported to S60 before too long.
Edited by Munkyb0y
Dynolicious is pretty cool but only ported to iPhone at the moment as far as I know.
Can't wait to get my car back on Monday to give it a proper go. Tried it out in my friends Golf GTi today and was pretty impressed. I am sure it's not 100% re power readings but still a cool novelty! Nice to play with between hands of Texas Hold-em :)
On another note, thoroughly impressed with the GTi, drove it out to the airport today and it was a good drive. Pretty quick stock out of the box :rolleyes:
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
