Full boost @ 4000-4500?
Yeah TiTAN - they have done a good job, it was kicking in at 5500 before, and now it's not the millenium falcon going into hyperspace "ie" head snap back when it kicked in, it's a very nice ramp up to power (still wheel spins in 2nd and 3rd if I'm a lead foot)
INVRTD - Check members rides - it's got all that motor talk stuff :happy:
Edited by Cpt. Rock
https://www.sau.com.au/forums/topic/230316-my-first-tune/#findComment-4047353
Nice work!!
Love the boys out at Autotech, Ed is the best :P How is there new workshop I haven't been out there yet?
Good Kat - more space - lots of nice skylines in the shop - still a little more work to be done in the office and most import, the cafe bar needs to be operational asap, it gets cold out there.
I think their web site is or will be up and running soon too.
https://www.sau.com.au/forums/topic/230316-my-first-tune/#findComment-4049420
Oh awesome. I shall check it out some time. Giving them a break cause I think they were probably sick of talking to me after I got my turbos fitted!
Is it this one that you mean: http://www.racingtherapy.net/autotech/
I giggle when I see it cause it looks more like an accounting firm or something!
https://www.sau.com.au/forums/topic/230316-my-first-tune/#findComment-4050935
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
