The diffence between the two are GTR measure 296 x 32 and GTS measure 280 x 30
I upgraded to GTR front brakes on my GTS and it is a worth while upgrade out on the
race track I had no brake fade at all and they felt very strong and consistent.I still used
the GTS rims (16 x 6.5) GTR are (16 x 8) and the only drama that I had was the the rim
was very close the the Nissan logo on the caliper about 2mm gap so what I did was file
the logo off and repainted them in high temp paint.With after market wheels this won't
be a problem apart from that it is 100% bolt on fit.The rear brakes on the GTS are the
same as early model GTR's same part number on the rotors and pads.
I think your money would be better spent on good pads, and when the 280mm rotor screams enoough then consider changing to another Skyline brake setup then, but i think you will find that on the street you wont notice any difference at all. A
At the track, if you go then i think again you will be hard pressed to tell the difference between the setups if you are running the same pads. But no doubt it is a good upgrade but maybe not so budget by the time you buy the GTR calipers, buy new rotors, and throw your pads in there it is probably a $1000 upgrade,
Not meaning to sidetrack this at all but a semi-relevant question..
Roy, What do you think are the biggest brakes to fit on the front of a gtst/gts4 under a 17x8 rim (unsure of offset but all inside guard)?
Currently I am running r32 gtr sumitomos with 296 rotors. I am thinking of going to dogbones and 324 rotors with these callipers.. do you have an opinion on this?
James.
Yeh, the 324mm will fit under majority of 17" wheels, I know i have never had a set of wheels that have clashed with my 324mm setup, and i have probably had 8-10 set of wheels on the car.
Biggest problem i have had is going to an aftermaket caliper with 330-343mm rotors which is when it becomes dependant on wheel types and quality, along with offsets etc.
33gtst setup is pretty much the same as 32gtr but a tad heavier, I'm running them but I put braided lines and a master cyl stopper in at the same time so can't really comment on just the calliper/rotor upgrade.
I don't know what people charge for 32gtr brakes but 33gtst would do the job without the gtr tax..
Alcon make 343mm, CSC/B-spec make 343mm. Performance friction also make 343mm. Project U make 345mm. RDD made 343mm, Biot make 340mm. Brembo/Stoptech/Dixcel all make 332mm. Alcon, AP and Wilwood all make 330mm. Just Jap and the G4/K-sport along with Greddy do a 330mm rotor as well. Then you have a bucket load of people making 324mm replacement rotors for GTRs and Supras
  • 10 months later...
After getting halfway through this project, and then finding that I needed to remove both front driveshafts as 3x cv boots were stuffed and had to be repaired in between, It seems that I have a rare set of 17" rims that the 324mm discs and caliper adapters will not fit under..
Seems that the inner diameter of these gmax m100 rims are just too close.
Just a heads up for anyone else heading this route. Now I have to work out which way to go.
ffs.
Edited by heller44
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
