Selling: R32 GTS-t
KMS: 148XXX
Price: $9,000 Neg.
Mods: FMIC, R33 Hiflow Turbo, Spitfire coil pack, 3" turbo back, Extreme Ceramic Clutch,
Coil Over Suspension and Turbo Timer.
Body: Silver, Stock kit, After Market front Bar - unsure of type. 18" avanti rims, almost
brand new tyres.
Interrior: Stock.
Stereo: Mp3 cd player, 6"s in front, 6x9" in back.
Reason for sale is Im upgrading to a GTR :down: has the car since last september, since then i had to hoses go (replaced with silicon hoses). thats the only trouble ive had with the engine. Had the timing belt (gates racing belt), tensioner and idlers, Fan belts (also gates racing belts) spark plugs, oil changed and water pump replaced at about 139XXX. so she is all sweet for a while. handles like a go kart :P
PM or MSG or CALL 0412 921 674
cheers joel.
*pics up tomorrow*
https://www.sau.com.au/forums/topic/230417-r32-gts-t-89/
oil, plugs oil filter changed last weekend.
pulled about 145kw @ 10psi.
willing to throw in an R34 GTR v-spec fuel pump (only done 40xxx). pump and remap easy 190-200kw
Need this gone people. open to offers.
https://www.sau.com.au/forums/topic/230417-r32-gts-t-89/#findComment-4065532
What's it like on fuel? And what coil overs does it have?
depends how hard you drive it lol. its pretty good tho.
im swapping the spitfire packs out for stock 1's.
ah wish i had the money for this, id snap it up nice a quick
:domokun:
https://www.sau.com.au/forums/topic/230417-r32-gts-t-89/#findComment-4075390
Im open to offers here guys.
I need this gone!
if got 2 stk rims at home i was going to put on there but obviously i need to source another 2. after taking off the 18s id be happy with $7500 so throw me some PMs!
cheers
https://www.sau.com.au/forums/topic/230417-r32-gts-t-89/#findComment-4082249
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
