Well Bulahdelah may not have a round of the NSW Hillclimb Championships this year but thats not stopping them letting us have some crazy fun on one of the best bits of road in Skippy land.
The 2008 Bulahdelah Speed Weekend is on the 20th and 21st of Sept with a Show and Shine on the Saturday for race cars/displays/market stalls/food and Driver fun on the Sunday.
If there's a piece of road more suited to hillclimbing than Wooton Way it could only be Bathurst's Mountain Climb.
I'd like to see a whole bunch of Skylines gridding up.
Neil.
https://www.sau.com.au/forums/topic/230568-bulahdelah-speed-weekend/
  • Replies 91
sounds brilliant. If the race car is not running (timing is about right for a run), we will bring the Z. Or the stagea. Or the bloody ute if necessary.
Everyone, if you are thinking about doing this hillclimb (best in NSW) don't miss out - these road stages are being shut down by the RTA and it may be your last chance :cool:
Everyone, if you are thinking about doing this hillclimb (best in NSW) don't miss out - these road stages are being shut down by the RTA and it may be your last chance :(
I drive this road a least once a week in my work truck...bit too twisty for me in anything with more power me thinks.
It's four lanes wide in sections. Do you actually know which part of the road we use?. I'm guessing NOT.
I've done it in my Skyline,in my Sports Sedan and can't wait to do it with the Radical.
Neil.
cmon Paul bring the truck up, I'll bring the ute (z24 navara). Then we can have some fair head to head competition :ermm: Being a hillclimb all you will need is an extinguisher, blue triangle on the battery(ies?) and a number on the door.
Like Neil said its 4 lanes wide + tarred road edges in some place, which probably makes it the widest piece of race track in Oz. Certainly wider than EC's main straight - makes for some amazing lines through the corners.
I used to have a Navara...its a TURBO Ford Courier now...i could fold over the actuator line and actually make some boost! :banana:
Neil im more than aware where the track is set out, a mate of mine is a regular racer there and being a Port Stephens boy its almost in my backyard.
Mate it's not that twisty,,,you start with 4 lanes and thats how at stays. You go through a left/right chicane up through a flat out left,,,flat out right and so on,,,I think I brake maybe 3-4 times,the hard bit is the last left because they narrow the road with withches hats to slow you down over the finish line. From memory I was clocked at 180 over the finish line in the sports sedan. Now thats quicker than most Skylines are going to be going only because I was on super wide sticky Avons.
But as you read at all tracks and in sup-regs "Motor Sport is Dangerous".
Neil.
Hmm I could be in for this..since I am addicted now and would like to try the "road" course..
Neil can I have a linky to the info,entry forms and price??
Where are you staying accomodation wise?
What's the average time for this course?
  • 5 weeks later...
I believe they have extended closing date for entry forms to tomorrow. Phone Ross Jones on 49972299 if you need more info.
I'll be there.
I'd given up on this meeting only because no-one was interested in doing it.
If your going then I'll ring Ross in the morning.
Neil.
Aww you guys are going now!! ;)
I need to fix my transfer case and with all the cars we have at the moment and saving for dutton I just couldnt this time..
Do post results after!!!
Which car you taken Michele?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
