Regarding the following mods to my R34 GTT, is my power figure in the ball park?
PFC
GCG standard turbo highflowed
Turbo back exhaust
Ebay front mount(!!!)
Splitifires
Greedy boost controller
Inclosed pod filter with cold air pipe
480cc Nismo injectors
Sard reg
Walbro pump
Tuned at 16psi, bleeding down to 14-15psi at 7000rpm
230kw at the wheels
https://www.sau.com.au/forums/topic/231028-decent-power-figure-for-gtt/
have u checked the boost the turbo is generating; rather than the pressure at the manifold/boost guage?
Just curious to see what the compartive figures would be with the ebay intercooler. Dont want to go cooking the hiflowed stocka!
...but yes results show nothing odd!
Thanks guys, I appreciate it.
I might look into the pressure drop over the Ebay special cooler. I have had lots of people comment on how good the core looks, but they are just that - comments.
Might be worth checking the temperature drop too??? Especially at Supersprints.....
Yeah its ok .. can pull more out no worries.. I run 260 easily can take it to 280 if need be. Highflow too .. but use cams.
In all honestly I was running that power with a SAFC, Stock turbo, Stock fuel pump (was fine not leaning), Stock injectors, Stock ECU, CAI and thats about it..215 minimum
So honestly 15more rwkw with a highflow and etc you should have more .. Get a new Actuator and hole to gate closed for quicker boost build and holding boost.. GCG sell them HKS do so also (one on ebay now)
Edited by DECIM8
Are you for real? A auto pulls 200rwkw Easily on the stock turbo.. I just watched a auto pull 201.5rwkw
Its an R34 GTT remember not a GTST.
I have been at the strip and easily beat my friend in a GTST with 221rwkw so you take what you will but you must be dreaming if you think that 220 is not achivable in a manual R34 with flow mods..
At the same time I did run a R34 with similar mods, Intake (cheapo like yours) and exhaust (cat back) with stock ECU and it was very held back.. I beat it by about 1.5 cars
Forgot to mention full exhaust.
Edited by DECIM8
Yes i am for real. 215rwkw, i bet you wouldn't even come close to running 111mph @ the strip, because with 215rwkw, thats right where you would be but id expect more around the 105mph just like everyone else.
You beat a car with more power by 1.5 cars? Doesnt that ring a bell right away to you?
Because it sounds like someone doesn't know how to drive if the cars had the same power, so again, it has nothing to do with power at all that example
next?
Look put it this way .. That car was also running a stock turbo with injectors and putting out 215rwkw with PFC, Injectors, PUMP, fuel reg etc
A GTST.. R33 .. On a dyno day at UAS I think (the last NSW dyno day?)
My car is faster than that.. or im a better driver .. either one your choice..
Point is 215rwkw out of a stock turbo on a gtst is that easy why cant I do it on my R34.. I think you need to see it real life.. If only I had a print out..
Surely someone has something to post up for him..
R34 GT-T
Stock turbo
Full exhaust 3"
Pod Filter
FMIC
SAFC
EBC
BOV
205.7 KW @ 12psi
Is the best ive found in the search in dyno results thread.
I must add I was running a Blitz SBC which gives better boost/power through the entire rev range supposedly.. May be this.
Oh even better
Edited by DECIM8
I agree with Ash, the most I could get out of my NEO is just under 200rwkw.. and that is with all the supporting mods required.
The stock turbos just dont have enough flow and 218rwkw at 12psi is a fair way out in my opinion. Even with HKS GTRS and 15psi I was only getting 236rwkw.. So are you telling me that a bigger turbo with more boost is only going to give me less than a 20rwkw gain?
Any Drag MPH's to back that power figure up?
Mine:
R34 GTT
3" exhaust
pod
splitfires
manual boost controller (turbotech)
pfc
hybrid fmic
202.9kw @ 9psi (peaks at 12psi), just under 7000 rpm
I also have fueling issues and can say from my exp that stock injectors wont run far over 200kw.. generally 100% duty cycle at 7000rpm
tuned at RE
Mine:
R34 GTT
3" exhaust
pod
splitfires
pfc
hybrid fmic
tuned at RE
Exactly.. mine at a little less power and running healthy AFR was nearly maxing out the injectors as well. I dont believe the stock NEO injectors will provide much over 200rwkw.
Here is my graph to back up what i said above..
Although, to add to the current discussion a bit more... i would hope once i have injectors, fuel pump and highflow/brand name turbo that i would be around 250rwkw at maybe ~16-18psi
Edited by nitestalkr
well I run 260rwkw with more to pull on a Rb25 neo engine why cant you guys do it? This was with highflow
I dont even have a FPR..
This is quite interesting now.
What other mods do you have?
I also have quite easily pulled out 265rwkw with the GTRS on a neo
dyno figures are meaningless unless you back them up with real world figures (like trap speed).
If you want to delude yourself into thinking you have 215rwkw on a basically stock motor with an exhaust and some boost, then go ahead. The 2 dyno graphs pasted so far both have been @ RE.. so im suspecting a happy dyno like ash said.
run a high 12 @ 112mph and we'll believe you.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
