hi
im in ireland and thought you guys might be able to help with some knowledge.
i purchased 2 new hks gt-ss turbos on nengun for my friends rb26 engined hcr32. he has done 2 drift events so far....
yesterday he lost all boost and came into the pits. i could hear a rough bearing noise coming from the front turbo. ... no smoke.
anyway we had a look and the shaft has serious up and down play and sounds very rough when spun by hand even. bearing is gone id say...
just wondering if any of you have had faulty hks/garrett turbos. im thinking the turbo got starved of oil somehow.... but maybe its a faulty turbo.
any feedback is great. car is running 430hp @flywheel on 1bar. rev limit is 8000.
thanks
https://www.sau.com.au/forums/topic/231139-new-gt-ss-blown-on-gtr-1bar/
Yeh I'm interested to see what caused it too. I'll be investing in a set of turbos in the near future which will be around the GT-SS or GT-RS / N1 size. I'll most likely be going with a set of Garretts (GT2560's or GT2860's depending on their badging)
These units would easily run a bar without problem? The boost level he was running definitely wouldn't have caused it???
The other day I was reading about oil restrictors on here....but you would've had that all sorted as you've no doubt had the turbos on their for a while?
The other day I was reading about oil restrictors on here....but you would've had that all sorted as you've no doubt had the turbos on there for a while?
for it to go that quick, i would say it was an oil/water starvation problem, or a serious overboost.
all you can do is take them off and have a look. hks or your supplier may look after you with a warranty if you can rule out the above
There is a huge difference between those two turbo's...SS is for Street and GT-RS should only be used in drag or race.
As for your friends blown turbo's.
Likely causes.....as stated already
Oil/Water starvation.
Oil blockage in line.
I suspect though a few things could have gone wrong with the install.
To have only used them hard twice and they are rat shit leads me to believe the following causes also.
Turbo's may have been knocked with a hammer to re-align with the manifold and then again to fit the dumps...it is tight and may have been belted in.
Was it an engine out job?
Boost controller fault.
When your drifting you don't get to see the boost gauges...and they may not be correct if factory OEM.
What Boost controller are you using?
How was it set up?
Good luck with the warranty claim.
How was it set up?
thanks lads,
my friend took off his turbo today and the banjo (orifice) bolt (hks part no. 1408-ra020) on the turbo is blocked. he says the hole in the banjos are tiny compared to the OEM oil feed banjo holes.
the car is a drift car and that day it peaked at 1.2bar. he has a profec b spec II. the solenoid is weak in it i think as it spikes quite high momentarily. my own profec b doesnt do this.
anyway i assume a tiny bit of dirt clogged the tiny hole.
thinking of rebuilding the turbo with oem sized turbo oil feed banjo's
can't do that mate, the restrictor is there to prevent too much oil getting to the core. You are probably better off looking into why there was something floating around the motor large enough to block an oil feed....was it bearing? ring? piston? plain old oil gunk?
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
