  • Replies 79
Posted Images
yay i found my car. first i checked home and no cars were there, so i tried my work and i found it in the parking lot, i couldn't believe it i didnt think i would find it but its pretty much by itself. carpark wasnt very full. its not a very clear pic cause you have to zoom in from the road to see the carpark but its definately mine.
found my place, the data seems to be from around nov 07.
It varies, i looked at a few places - the one of my beachhouse has a friends car out the front, she didn't get there until late dec.
And another place on the other side of the state has a path i built in it early january shown pretty clearly.
Edited by baron25
GTIRR - Andrew found his wife carrying shopping and Flash found his overweight dog in the driveway.
Saff - Barge from the carpark next door parked out the front of the apartment.
says the man with the slippery couch tacos
i went to my gf's house and saw someone (hard to see who) in her front yard.. so i msgd her saying "aha i looked on google maps at your house" etc etc
and she replies
"oh no! no ones home today im so worried!!!"
:P
people shouldnt really put their address on their online resume's - too easy to keep track of their house now...
Why? it's not like the photos are in real time...The streetview photo of my house is almost a year old and the satellite photo is over 3....
The photos were taken over a 6 month period...
Pretty sure there still going aren't they? saw one of the cars the other day.
Found a few skylines round my area too :woot: and somebody gettin in their car round the corner :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
