Just got my car back from the tuner after some major installation work, including new turbo, afm, injectors, cams, etc. I am extremely happy with the power output and response and the tune in general.
After lots of dyno runs we haven't been able to figure out the latency required for the injectors. The guys tried everything from positive latencies through to negative latencies. We have settled on what appears to be the standard for these injectors, 1.6ms, however the injectors seem to be dumping a bunch of fuel whenever I come off the throttle, which is igniting in the exhaust.
Anyone have any probs with these injectors in the past? Anyone know of a more appropriate latency for these injectors?
I have done a bit of research on the web and all I really come up with is 1.1ms or 1.6ms and both of these were tried and still result in issues.
https://www.sau.com.au/forums/topic/231393-sard-800cc-injectors-latency-help/
one would assume the latency is wrong
how does the correction look? is that normal and relative to their size vs old injectors?
how did you find the AFRs when tuning it - did it need tons of correction on the INJ map or was it fairly OK?
http://www.sardracing.com/products/Injectors.htm If you don't have that already.
Got that one, but thanks! :google:
reserved while I get more info...
Likely not latency but rather the bov setup and or accelerator injector time.
Mine had an issue where light throttle accelerating with traffic from first to second it would often back fire through the exhaust. Tweaked the accelerator injector time and cleaned it almost all up.
The only time it now pops etc is due to AFM reversion as I don't run a BOV. So give first a little bit of stick and slow shift in to second almost always gets a little flamage out of the exhaust.
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
