bah, i was stuck in line at Belco bunnings when it snowed (literally started as i entered the queue and stopped as i left the store, i felt robbed)
Also i started riding my bike to work last week, takes a good 30 minutes for my face to un-numb but im saving $150 a fortnight on petrol and parking :whistling:
https://www.sau.com.au/forums/topic/231704-its-snowing/#findComment-4074826
Also i started riding my bike to work last week, takes a good 30 minutes for my face to un-numb but im saving $150 a fortnight on petrol and parking :)
haha, o man, i tried that.
i got about 20mins down the road, locked bike at a bus stop, and picked it up the next morning in the ute :D
points for effort, you'll be bloody fit/beowulf in no time.
https://www.sau.com.au/forums/topic/231704-its-snowing/#findComment-4075454
damn i missed the chance to try the stagea in its proper environment :D
and i know whats its like on the bike too. i rode up the parkway on my motorbike, stopped to get some petrol and i couldnt speak properly to the guy at the counter because my face was so frozen
https://www.sau.com.au/forums/topic/231704-its-snowing/#findComment-4075816
