One very big make over, you'd wonder why it didnt get something a little different done to it, rather than making it look like a stock S2, save rims/colour etc
S2 had driver and passenger side airbag standard...so i guess you could check that, doesnt it have it written on the passenger side dash when you airbags?
Not that S1 was all that different from S2
https://www.sau.com.au/forums/topic/23207-my-skyline/#findComment-511876
As far as I'm aware......S1 lasted until the end of 94 had no airbag and low rear spoiler. S2 started early 95 easiest way to tell had driver airbag & higher rear spoiler (m-spec). In 96 the S2 had an update which included the front spoiler (with fog lamps) and a higher bulge in the bonnet (which are fitted to your car). The 96 update also added a passanger airbag.
I'd say that if your car is a 95 it has had an update with the 96 frt spoiler & bonnet and a new paint job
https://www.sau.com.au/forums/topic/23207-my-skyline/#findComment-511895
  • 2 months later...
  • 8 months later...
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
