just looking at doing cams on my rb25det neo
just wanting to know what people have done
resaults before and after
driveability
power delevery
where the power changes etc
any dramas people have had
thanks in advance
and any thing else u can think of
https://www.sau.com.au/forums/topic/232770-cams-r34-gtt/
260 deg poncams type B.
they seem to make more power everywhere (10-15kw with a HKS GT-RS) with a slightly lumpier idle.
need to check valve clearances (+shims) which can add to the cost of installation.
depending on your application they are a good thing but if you are chasing higher peak power it will be cheaper to buy a bigger turbo.
https://www.sau.com.au/forums/topic/232770-cams-r34-gtt/#findComment-4082884
i have following mods
gcg gt3076
sard 650cc injectors
splitfires
pfc
avcr
fmic
3'" dump apexi ni evolution 3.5" cat back
sard reg walbro pump
hks fuel rail ( latest edition
z32 afm
car needs a pfc retune
so figured miswell get something else done at teh same time
with gtt solid lifters does it need shims?
https://www.sau.com.au/forums/topic/232770-cams-r34-gtt/#findComment-4082934
head stays on with poncams but will probably require shimming. the factory valve clearances are different from the recommended valve clearances from Tomei. some of the smarter guys here might be able to clarify if factory clearances are ok or not in the real world.
https://www.sau.com.au/forums/topic/232770-cams-r34-gtt/#findComment-4082965
Almost positive you will require shimming. I have Tomei Poncams in my GTT and the tapping sounds like a machine gun. The factory valve clearances are definitely different to Tomei's.
It was suggested to me that it wasn't causing any problems, hence why I am driving it, but I will be having mine shimmed soon anyway.
https://www.sau.com.au/forums/topic/232770-cams-r34-gtt/#findComment-4083527
