  • Replies 1.1k
Then changed, derailleur, cassette (again, 11-21t dura-ace this time)....
may i ask why the hell you put a road bike derailleur and cassette on a dirt bike? if you say to save weight i am going to slap you, as there are much better things to spend money on to save weight (things that cost less and will save you more weight)
anywho, here is what my next bike is going to be. hopefully have it by xmas. my mtb is ok for when i got for a ride with cherie, but when i go out for a hardcore sprint around town like i did on saturday arvo it isn't that good. just not quite as comfortable for high speed riding. i just have to sell a bit of stuff to get it.
well its not a mountain/road bike but ill let u all know bout my old sk8park bike!!
its a 2006 DK Cleveland
looks like this
but it looks a lil diff now...
bought it for $700 new
its now got a Hazard light rear rim- $200
tuffneck 3 piece crank- $250
primo rod seat post- $50
primo pedals- $80
DH pig pro bearing set- $75
Dual brake line setup (rear only) whole thing cost around $200-$250
blah
blah
blah
cant b bothered writing it all atm cause i forget. i think im close with most prices...
ill post some pics of my bike up tomorrow!
its for sale too... put a fair bit of money into it back in the day. most top range parts.
looking around $550 for it. perfect for skate park or dirt jumps :(
forgot to take a pic today. been tryin to get the stickers off and make it look good to sell :D
Stagea girl- to my knowledge, mongoose arent really worth much these days unless they're brand new and the higher models. wat is your son planning to use it for? if its for him to just ride around the area or to school then it wouldnt matter if it was old. all you would need to do is spray it(only if needed) and buy some cheap parts. but for a more stressful (on the bike) application such as bmx racing, skateparks or dirt jumps, i would recommend a newer stronger frame otherwise u will just be up for more money wen he starts breaking things :D
think of it as a car. inferior parts= constant replacing, superior parts(unfortunatley more $$$)= stronger and long lasting.
i had my pushbike for a few years and gave it hell. daily use on skateparks with stacks onto concrete from decent heights, landing wrong where ive broke bones instead of parts on the bike, hit trees dirt jumping etc etc... and its still in near perfect condition! because i forked out on the higher quality, i havent needed to replace anything since i upgraded the different parts.
well im ranting on...
Edited by auss13
mongoose aren't worth shit unless they are the ones from the 80's. and if it is a few years old it wouldn't be worth much even if it was a high end model. bikes have changed so much over the past few years, and gotten cheaper. what you used to pay $1000 for about 5 years back you can now get for about half that.
I have an old mongoose frame, was going fix it up for my son, but the bike shop said it wasn't worth it.
Anyone know about mongoose?? They worth anything these days?
If its a Supergoose I'll buy it off you. :D
ok well after looking at the pics, i can tell you that you will be lucky to get $300 for it. sure it might have an odyssey rim on it, and sealed bearing cranks but that is about all that's good. the actual crank arms aren't that good, just the bearings. for $550 you can pretty much buy a 2008 model cleveland, and it is better spec'd. but if you can get $550 for it then well done.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
