problem is that the pedestrians are the ones who are the risk to the cyclists. the dopey flamin mongrels with ipods who step out in front of them without looking. in fact i had one do it when i was in the car. didn't even look just stepped out onto the road. luckily i was watching him and thinking to myself "i bet he doesn't even look". wasn't a young guy either. he was probably 55.
  • Replies 1.1k
My Sled
62cm TREK OCLV 110 5900 Series road bike
Touch under 5 grand when I got it
Love the thing.... Nearly as much as my GTR
But due to work havent ridden in 3 years, I will be hitting it hard in 5 weeks.
Time to get back onto her.
57cm is a stupidly tall frame for a mtb though. generally made for someone well over 6 foot, generally 6'6 or taller. jase 50cm or 55cm would suit you. i only ride a 50cm and i'm 6'3. sure i have the seat the whole way up, but i prefer shorter top tube lengths.
road bikes on the other hand are sized totally different to mtb's. well not totally different, but generally you take a different size road bike to mtb. a large frame road bike will be around 57cm, and extra large will be around 60cm. the top tube lengths on road bikes will often be shorter, because of the difference in handlebars and stems. for example, in the 09 stuff, the bike you have jase in a 20" frame (50cm) has a 589mm top tube length. but in the road bikes, a 58cm frame bike only has a top tube length of 585mm.
going to a bigger frame won't help too much with that. if you go to the next frame size up the handlebar height comes up by 20mm, but it is also about 10mm further away. your best bet would either be a steerer tube extender or a stem with a steeper angle. the stock stem is only 5 degrees. my bike has a 40 degree stem on it.
this is the only pic of it i could find on the computer. you can see the angle of the stem and how much higher it makes the bars compared to yours
caad5 frame geometry, compadre. i'll still beat your shitty bike :thumbsup:
my friend saw me riding from her car yesterday and speed tested me said she speed matched me at 45 kmh
i was like
fk yea
i have one of those "big bike ride" things on the 22nd - it's a 60 km ride... my first like... "charity ride"
can't wait!
62cm?!!?
that thing must be huge what do you feed it!?
Mainly beer....
You forget that I am somewhat not normal in proportions to the rest of human race....
Damn milkman being 22 Feet tall....
:thumbsup:
got an apollo altitude 24" (61cm) mtb last week ..it's only a $500 bike but who cares. The standard mtb tyres are a bit of a pita for the road/footpaths, was wondering if changing to a 1.5" slick tyre (stock one is 1.95" knobby) would help in riding on the road to the shops etc ?
found these really cheap slicks at $16 each at torpedo7.com.au with good reviews ..worthwhile upgrade??
yes they will make a big difference. i run them on my bike. you could even go skinnier if you wanted. i run michelin 26 x 1.4's on my bike. they are a more expensive tyre because they have a layer of plastic between the tread and the canvas to prevent punctures. you are looking at about $40+ for one of them though. but you can run them at 90psi, which also helps you roll faster. the stock tyres on the altitude you can only run up to about 60psi.
and a 24" frame? how tall are you???? must be pretty tall to ride a 24". i find even the 22" frames feel big.
and that reminds me. i should go build some altitudes because i sold all the ones i had on the floor. pity you weren't in qld though, cause i am selling the altitudes for $400 (09 models though, which are pretty much identical to the 2010 model, just different colour)
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
