go right ahead then, up your pressure 5psi or 10 psi. Then add the rising rate of 1:1 to it. I run 22psi on some days, hmmm, that would give my standard injectors (if they were still fitted) a good, 20psi+ extra pressure. And people with the stock turbos, gonig from 7psi to 13psi, thats an extra 6psi, plus your claimed 5psi or even 10psi. 10psi to 15psi is not only a lot of pressure, but a lot more flow for these 15yo injectors..
You'd rather risk doing that, and blowing your engine, than getting new, fresh injectors?
Do you know how many GTR's and GTS-T's I have seen with stuffed injectors, running at standard pressure? Oh, but you're the expert. My bad.
Edited by The Mafia
  • Replies 71
I won't tune a car with a malpassi FPR now. I turn them away till they put a stock one back on or get a sard or similar
Last one i had on the dyno had 3 different AFR's on 3 power runs in a row... 11.5 12.5 and 13.5 LOL. those damn italians.. they think they are gods gift to the world.
ALSO i would get rid of that ECU. it is shit. Sorry to break the news to you.
yuck.
The last 2 cars I tuned, we had to take them off and bin them.
The AFR's would be from one extreme to another. You go WOT, the AFR's would go to 11:1, not touch the tune, then WOT again on the next run, 13:1. Put the standard one on, and AFR's would hold perfect.
They are junk.
have you found any info about the latency of your injectors yet chris?>
Nothing that refutes the info my current tune is based off unfortunately. Ah well, loving the flames for the moment! My fuel efficiency sucks though >.<
from what i have heard... but it depends on where you want to take the car...
for the 300 rwkw you mentioned you'll want a better ecu, bigger turbo (hks 3037 pro s or similar), injectors, fuel pump, Z32 afm OR map sensor'd ecu, cams are an option and then you'll be dancing around the limits of the stock engine.
300 rwkw is expensive in gtst form...
stick to 250-280 tops imho
280 is pretty good tho right? hmm alright...
i have heard good things about Power FC and also Wolf seems to have a few ppl happy with it..
what do you guys recommend?
Also will the SARD 550CC injectors do well with the power i want to reach?
Edited by palmer
yeah the 550's will be fine but as previously stated bombtrack is having latency issues with his... they are shooting fuel for too long and makin teh massif flames...
nismo 555's are probbaly the easiest option
power fc > wolf
haltech also a good ecu option...
ok
so get some Nismo 555 injectors, Z32 AFM, maybe some Cams and see how it runs with the EMS Stinger at the moment... if im happy ill leave it... if not sell the Stinger and get a Haltech or the Power FC
what fuel pump would be a good option?
the EMS stinger is a map sensor ecu so you wont need the Z32 AFM.
Just get the injectors turbo and see how you go with your ecu. if you like your engine and want it to last id get something else.
But try your luck. a new engine is only $1500
:D
I post this;
Discussing this with you seems pointless since you have nothing of substance to argue with.
Then you post this. You're blind, and possibly stupid.
I said exactly this about 10 posts back, and agree with you 100% Guilt-Toy, I refuse to tune cars with them installed because they completely waste my time trying to diagnose fuel pressure problems.
Factory ones work fine.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
