hey guys
looking at getting a plenum for my rb25 there are alot of cheap chinese manifolds that need alot of cleaning up (porting) and dont flow that well. does anybody know of any plenums available with good flow short runners and preferably fabricated alloy plenum chamber something like hypertune.
https://www.sau.com.au/forums/topic/233027-whats-the-best-rb25-plenum/
well its depends on your setup, cams, turbo application and of course budget, the greddy one works well and i have never had an issue with one, the hypertune stuff is killer but more expensive and would suit somehting more radical. The cheap thai stuff on ebay seems to work real weel on RB20 but im yet to use one on a rb25.
whats the finish like on the cheap thai stuff how well does it fit?
i get these ones : http://motors.shop.ebay.com/merchant/pnt_performance
the other ebay ones (Greddy Copies) ive used are shit, i will NOT fit them regardless... ive seen quite a few leak coolant into Number 1 runner and various others crack after a few months (dont ask me how in the world they could make it so crap that it cracks but they did)
i buy heaps of those ebay plenums made in thailand but i only buy the plenum half
i sent them an email asking if they would sell me the plenum half on its own and they agreed the reason why i dont use there whole plenum is because i dont like there runners and trumpets, i dont like the shape of the trumpets and i dont like the ruff casting of the trumpets so i only buy there plenum half on its own and use my own custom runners/trumpets
the plenum half is unreal! its casted, nice looking shape, good size and its very very thick and they also sell the plenum half on its own for a pretty good price
tuff maybe you can supply me one of your "modded" versions next time to have a play with? i would rather pay some-one local (and a community memmber) than send the coin offshore ? providing of course they are indeed superior in the runner department.
thats the kind of info thatim interested in thanks for the info ill see whati can get my hands on as far as runner
if any body else has helpfull info it is greatly appreciated
thanks
plazmaman use factory runners which are fairly long aswell i was trying to steer cleer of the long ugly runners
thanks guys im thinking jun copy plenum chamber and custom runners might be the trick
ill let you all know how well it works (before and after dyno results)
thanks
keeps ideas coming if you have any others
I got a plazmaman one and no comlaints here, but yeah the factory runners look like dick. Thinking if i take the head off to clean out the casting marks on the inside of them and then getting the outside chrome dipped to match the plenum :D
  • Like 1
to be perfectley honest the best upgrade ive done on RB25 is std RB26 individual TB's and plenum. on a std GTT (neo) expect a maximum increase of 40hp and no dips below the factory torque or power curve. The response of the ITB's is awesome and the flow of the factory GTR is great (nismo is better all round) but expect to pay similar money for the comlete setup when comparing it to a greddy setup with Q45 tb etc etc... I know RACE PACE now has the (BEST) conversion kit available for this swap, it is based on the BLITZ D1GP kit.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
