Hi,
There is a group buy going for the B&M line lock kits, and i was just wondering if any of the drag racers out there have installed them in a skyline. The reason im asking, is because a place i was going to buy one off ages ago said that i'd need two kits to make it work on a skyline. I dont really understand why, but it turned me off the purchase.
I just wanted to confirm whether this is correct, and ask where on the car have people installed the solenoid and cut the brake line.
Its kinda related to forced induction.
Thanks,
Shaun.
https://www.sau.com.au/forums/topic/233090-line-lock-kits/
only need one, also if your using it to lock on the front, or lock out the rear, you must reverse the flow path depending on what one you choose. If you locking out the rear install it in the reverse of the flow direction on the valve.
Edited by GTR1993
https://www.sau.com.au/forums/topic/233090-line-lock-kits/#findComment-4087895
Yeah, mine has ABS.
I just got under the sar, and there is only one line going from the front to the rear, then it splits to each wheel via a distribution block.
Ill upload a pic of this block. Good to know.
Its a very small diameter line to flare though; i wonder how hard it is to install.
Shaun.
Edited by Shaun
https://www.sau.com.au/forums/topic/233090-line-lock-kits/#findComment-4088118
Guys you don't put them right....
You must put this solenoid in your front brake line.
If at the brake master cyllinder there are 2 line for the front brakes you need two line locks if you have only one line you need one line lock.
The differense is if the car has or not abs but I don't remember which has two and which one!
You put the BRAKE pedal!!!!
You push the bottun!!!
Leave your brake pedal and forger it...!
Feel free to PLAY with your clutch and your throttle pedal only...!
When you finish the burning.... push again the botton...
AND.... GO!!!!
If you put them in the rear line you still need to push 3 pedals with two foots :wub::P
https://www.sau.com.au/forums/topic/233090-line-lock-kits/#findComment-4105995
Problem with that is what if you want to crab walk (aka crawl forward) while doing a burnout. Ide rather have to heel toe it and be able to do rolling burnouts than a boring stationary one
Ps. Installing one of these at the moment. Watch the fittings you put in to them cos they are american and require a special tapered fitting to seal properly. Got an adaptor from a brake parts store but not before I wasted time trying to make my own lines.
Edited by rinmak
https://www.sau.com.au/forums/topic/233090-line-lock-kits/#findComment-4106006
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
