Apparently they will soon allow 7 letters in VIC for plates.. That is what I have heard anyway.
Most of the ones you can think of have probably already been thought of unfortunately.. DAZR34 would be appropriate..prolly could get that..
https://www.sau.com.au/forums/topic/23318-r34-plates/#findComment-499745
Originally posted by CR34TION
sky034.. hmmm i want it...
Originally posted by Daz
nice plates rigga
nismoR34: As above?? :)
Usually the first thing most people say about my car (SKY033) is "Love the Plates", "Clever Plates" etc. The best part about standard issue plates is they dont carry the pretentious reputation associated with custom plates.
Today we'll open up the bidding at the very reasonable price of $500.
Do I hear $550? :D
https://www.sau.com.au/forums/topic/23318-r34-plates/#findComment-499930
You have heard wrong.
I contacted VicRoads just after this rumour started circulating, and was told that it's not going to happen.
And riggaP don't be so tight....
Sell the bloody plates.
Otherwise they'll never end up on a car.
I'm just glad that you weren't greedy enough to take into account the fact that someone would want SKY031 as well. :D
https://www.sau.com.au/forums/topic/23318-r34-plates/#findComment-500077
Nice plates you got there ;)
Yes you are right about 7 digit plates. Vicroads dont even know whats going to happen yet. Theres a few options, they could go backwards, adopt the NSW configuration, or go with 7. After being on the inside at VR, this decision wont be made for a while...
Tight? Consdering NASDAQ in NSW went for some ridiculous amount (like $150k) and I've seen plates like BAY13 for $10k, BROCKS for $15k, and BLKHSV for $5k, I thought $500 was very reasonable. I dont really care if no one buys them anyway. I'll just put them on my 34 when I upgrade :D
https://www.sau.com.au/forums/topic/23318-r34-plates/#findComment-500109
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
