Hey peepz,
Just thought id post up some pics of my car as i am the kid on the block! wave.gif
Let me know what ya think!
Word
Nice one you got there, miss. Did you buy it recently, cuz I saw that V on carsales while back.
Welcome to SAU.
Top secret gold GT-C FTW too. :)
Hey all! New here :)
Unfortunately, I think I was born on the wrong side of the globe! Hoping that I can become part of the community here and see how others mod their Coupes in other parts of the world - as I have looked to Japan and Australia for ideas over the past few months on how to fix mine up!
How it sits rolling down the hiway, bit lower and cambered now. more to come soon!
Hey mate I'm loving the way your car looks!
Where can I get those front grille and clear indicator lights? I'm after this sort of clean look for my V35
What's the front lip and where can I get one
I check out his FB page (Facebook.com/RainbowBriteG35) to find out a little more. The lip is a URAS item, apparently the very first URAS lip in the USA & only #5 in existence (as of Jan '12). As for suspension, running a Stance Solutions + Air Lift suspension kit for that slammed look (http://www.stance-solutions.co.uk/1). Lots of other mods under the carbon bonnet too.
This is my white 2002 V35 250GT, fresh after a wash'n wax before JDMST.
Got her from Japanese Motorsport Direct in Revesby, had heaps over V/M nissans.
3rd nissan, wont own anything else.
Just had these 18s put on, got them cheap off a mate (came off a toyota chaser) and fit perfectly.
More low is on the way along with exhaust and some other things.
Yeah I remember that car, I have pics of it on my phone.
Yeah getting new front and rear bars with new reo for the back (someone hit me) then colour coded all round.
Would kill for the WALD kit tho
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
