I'm sure a lot of you have seen my car anyway... But here is some pics:
Can View more at http://www.sgv35.com
Beautiful car... maybe you should put your interest down here:
http://www.skylinesaustralia.com/forums/topic/393123-qld-photoshoot-by-tangcla/
I just picked this car up the other week, some of you may have seen it around Brisbane before with the previous owner. Most of the shots are from a Forge photoshoot before I got the car.
20" Forge wheels, Brembos, leather, bose stereo, coilovers, exhaust and a few other bits and pieces.
Overall really happy with the car. Just have to sort out some slight scrubbing problems on the front when hitting bumps and see if I can get the screen fixed. No picture showing up so I can't see what I'm doing...
Has anyone experienced any headlight problems with these lights? They don't seem all that bright on low beam?
Also I seem to be getting a "tick" noise when taking off and sometimes when changing gears. Sounds like it is coming from the rear brakes?
Hey Goodys, nice ride. Yeah ! Mine developed a ever so small "clicking" at around 60,000klms. Its so faint that even my mechanic cant work out where its from. I m pretty sure its a cv joint to the diff. I notice it when I first take off (sometimes 2nd gear), but definitely when you reverse then go forward.If it gets louder I will investigate further , but too minor to worry about now.
As for lights- the only issue with all skylines Ive had is the front passenger side parking buld. Usually just give it a bump & its good !
I just changed to LED'S as well as interior & wow thats good bang for the bucks!
Thanks for the info mate, I have a hoist handy so might have a look around and see if I can find anything near the CV's.
I just got home from a drive and decided to actually have a look at the lights while they were on and it seems I have 3 out of the 4 low beam lights out haha. I think this might be my problem. I will hopefully pull them out tomorrow and see if they are stuffed.
For anyone interested the wheels are 20x10 -0 with a 5mm spacer so effectively -5 front and 20x11.5 -0 rear. Not sure what the camber settings are or if there is much adjustment in them. Need to bring them in a little bit to avoid some scrubbing on bumps.
Also which interior bulbs/LED's did you replace? Any pics?
Yeh sounds like you have a short somewhere in the wiring. Replaced the Parking lights, Interior -headlining and door lights, boot and number plates also.
Just need to buy the clear indicator lense now. (had the car 4&1/2 years and just woke up to it now ! lol)
Anyone recommend somewhere in Sydney that sell them ??
I will post some pics when I do these.
Had a mess around today and it looks like it is just the RHS low beam bulb which has blown. It does not actually look blown but after connecting it to a battery I am still getting no light.
Will going to a "whiter" light give a bit better vision? How it is now I can't really see all that good on low beam..
Right now they are more blue than anything.
The lights are after market but not sure exactly what. Pic attached.
It's the rear axle bearing.. Very common problem with v35 Skylines.. It's nothing major.. Just an annoying sound
Edited by Megahowler
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
