Ok I posted this in another thread but I thought I would start another about the Auto and modding, mainly changing the ECU.
Who here has a Auto GTS-T and has changed there ECU? has anyone tried using a APEXi power FC on there auto Sky's? I know everyone says it can't be done but has someone actually tried?
I got in contact with Wolf regarding there ECU's controlling the auto, anyway this what I got back.
What I asked:
I have a R33 GTS-T Skyline Auto and was wondering if your Version 4 plus plug in can be hooked up to and control the Auto Transmission?
Reply:
We have had people run the Wolf on R33 auto's, we are not controlling the auto trans.  I have not heard back a response about how the auto trans works without ecu control.
Then I replied back:
Thanks for the reply, this is something I'll be keeping my eye on, as far as I knew the Auto needed input signals from the ecu for it to work probably (to change up and down gears etc.) that's why you can't use ecu's like the Power FC.
Reply:
I know of one customer who has used the plug in R33 ECU that we make on an auto R33.  I don't think they have had any problems.  The car does change gear, it was driven from our factory.
Now I'm bloody confused, so if the Wolf3D isn't controlling the Auto then what is? Does it really need to be controlled by the ECU?:confused:
Any body else got any ideas?
https://www.sau.com.au/forums/topic/23333-wolf3d-with-auto-r33-gts-t/
  • Replies 97
Guest RedLineGTR
there are two computers for the auto one is the main ecu and there is another computer for the auto itself this computer just gets certain info from the main ecu. Thats how i see it just ask a friend or someone who has one to pop it in your car and see what happens
i dont know about skylines.
but on the 4age20 frount cuts i got. there wasnt a second computer for the auto. it was simply the main computer controlled the auto. the reason for this is to help smooth out the changes.
auto and manual frount have different model computers.
That's cool GTS-t VSPEC, thanks heaps.
Just seeying if anybody else has done anything, there seems to be a few people with auto Sky's and I don't think I'm the only person that would like to do something like this.
Craz0 i'm in the same boat. Have done a little bit of research and talked to Dr Drift here in Melb from BMT.
The only think I can think of beside the full house Motech is the E-manage. The only problem with this is that the ignition harness for some reason doesn't response to the auto ecu. Guys at BMT are still working on it to see if they can figure it out. Something to do with signals interference.
I'm not sure if Link comp can take care of the auto ecu but I was told by my mechanic that it can support it. Unichip could also be a possibility.
But at the moment I'm looking at the E-manage as it is the cheapest out of them all.
Cheers
Yeah there isnt to much after market support for the auto's.
I was just going to get a SAFC II and a AVCR and call it quits at that, but I thought I'd have a look into it before I set my plan down for the auto sky.
I was cheeking out TakaKaira and Buddy Club have a Race spec computer for the auto, click here then use the drop down second from the bottom
http://www.takakaira.co.jp/performance/main.asp?maker=160ℑ=buddyclub&name=Buddy Club://http://www.takakaira.co.jp/performa...name=Buddy Club://http://www.takakaira.co.jp/performa...name=Buddy Club but I don't think there is a Buddy Club tuner in OZ and it doesn't help that I'm in Central Qld.
craz0: I thought that AT computer from Buddy Club was for modifying the automatic transmission management. EG: Faster shifts, holding gears for longer... Similar to the power button but with more flexibility...
OR, is it similar to the Buddy Club engine management but with extra features for the Auto?
Has anyone tried a Power FC just out of interest? Maybe it works? :D If not, the symptoms may help with diagnosing a solution....
I'm not a 100% sure know you say that:confused:
Well AP Engineering modified the Power FC for the Auto Toyota JZX100's so I'd say it would be pretty much the same to do it for the Skylines, well I think anyway.
I have read up on the Buddy Club on Takakaira and the impression I got the automatic function on it is similar to our POWER button. I think it will hold gear for longer and down shift quicker?!?!
Craz0 I was thinking about the same thing about getting a SAFC2 to adjust the fuel curve and leave it at that. But I still think that the E-manage will be better than the SAFC. The SAFC only have like 12 tuning points whereas the E-manage have alot more than that if tune with a laptop and harness.
If you think about it an SAFC2 at the moment cost around $500 to $700 depending on where you get one and the E-manage cost around $700. After tuning and installation you are only looking at about 100 - 200 bucks difference. For that reason that is why i'm still sticking with the E-manage. And if someone can figure out the ignition problem it will even be a bonus.
If you are thinking about getting the ACVR as well, why not get the E-01?! This way if you have the E-Manage and he E-01 you can boost your Skyline as well be able to tune it (fuel curve) using the E-01.
Go to the Vic forum and there is a tread there on 'What is E-manage'. You can find out more info there.
That's what I would do, but I'm no car mechanic hehe.
Cheers
I currently have an R33 series 1 auto with the PFC in it. (and have had no problems).
Later this week I am getting a modified auto installed (tighter shifting and higher stall torque converter). I will post next weekend an let you know how it went.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
