  • Replies 97
craz0
so now with the pfc in everything is fine and all u had to do was plug in with no extra wiring or mods to to the unit or wiring to make it work with the auto?
the only issue u have is the power light flashing?
steve-sst
how much is a wolf plugin worth for a r33 auto gts-t?
and who can tune it in sydney?
and as craz0 said when you installed the wolf into the auto r33 did u notice the power button flashing/going through the diagnostics?
Originally posted by walkoau
craz0
so now with the pfc in everything is fine and all u had to do was plug in with no extra wiring or mods to the unit or wiring to make it work with the auto?
The PFC worked and you can drive the Car, but the Auto speed button would flash 16 times (all fast) and when you run the Auto through diagnostic mode the third flash would be long (Throttle sensor shorted or disconnected) so the Auto needs the TPS signal to work properly, when I took it for a drive it would hold out through the gears (e.g. would change from first to second at about 3500rpm with your foot just on the accelerator where it would normally change under 2000rpm) after braking/cornering and then accelerating it seem to be in the right gear (like it wasn't fishing for a gear), It kicked back gears fine as well. When it did change from first to second it was harsh (like when you put your foot down from first to second and it gives you that kick but just not as fast and no wheel spin :P)
I can't seem to find a pin layout for the actual Auto ECU either.
Does anyone know what info Pins 5, 14 and 15 push from the main ECU? all three of these go straight to the Auto ECU.
I'm figuring they push the TPS and maybe Tacho signals so the Auto ECU can figure out when to change.
I've attached a pic of the three wires going into the Auto ECU.
Just seeing if anyone knows for sure.
  • 1 month later...
Ok i got the wolf plug-in and I pluged it in and the car didn't want to start and when it did it coughed and farted and blow dark black smoke and the lights on the ECU looked like Christmas lights going of,so I turned it of :confused: don't know what happened here.
The user manual I got with the ECU is for the normal Ver 4 but not the Plug-in version, I've contacted Wolf about this and I'm waiting on a reply.
Steve-SST do you know if there is different versions of the plug-ins at all? mine has (rev 5) on it, also the PC software I got for it is Ver 4.49 what version are you currently using?
So the MAP sensor has to be conected for it to work properly? so where is the best place to hook in the map sensor line? the fuel presure reg line?
Can you still leave the AFM hooked up or do you have to remove that as well?
My car is a 93 R33 RB25DET Auto everything is stock other then a Jamex filter in the original box and I run it on Optimax.
Steve Taylor sent me the first draft of the Installation Manual for the R32/R33 GTST Plug-In ECU, I haven't had the chance to read over it yet and the manual isn't quite finished.
Thanks heaps for your help.
My Email
Originally posted by GTS-t VSPEC
You can still leave the AFM in if you want, but just make sure in the software to choose MAP sensor. Try and get a clean plenum line if possible for the MAP.
What do you mean by "Try and get a clean plenum line if possible for the MAP"?
Where did you get your line plumed into?
Thanks GTS-t VSPEC
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
