  • Replies 174
Posted Images
If the Australian government was smart they'd arrange to run more rallies all over the country because you can be sure it would be a fail safe way to end our draughts. Because it seems nothing ever brings on the rain like a rally!
LOL Snowman - very true !
- Adam
Isn't it only the AASA rallies (TT & WPT) that allow downsizing of rims?
Correct Duncan. Thats why I'm suggesting Russ doesn't do anything rash and spend a fortune on downsizing brakes/rims untli every rally he'd like to enter is either with AASA ot CAMS follows suit with the rules.
Yeah but I also read somewhere (it was on the internet so it must be true!) that Nissan have even stated that they know the R35 is FASTER with smaller wheels but fo physical symetry they were forced to run with 20's.
So the question is if you can get better rubber for 19's and it's known the car is faster on 19's then why the hell wouldn't you get a set to use when you CAN run 19's?
I think the Lambo guys mainly use the Toyo's right?
But otherwise there is the Pirelli Corsa and Michelins Sport Cups.
None of them are as good as the Dunlop/Bridgestone/Kuhmo semi's (which don't come in 19's I'm pretty sure) but they have to be better than street tyres.
The Toyo's are definitely good in the wet and they also come up to temp amazingly fast (for sprints your out lap is almost your fastest lap) but they don't have the absolute grip of the others but maybe in a rally they'd be good?
They are also funny in that people say they get faster as they get worn down too.
A simple application to CAMS would see you permitted to downsize rims. I was pushing it with them last year until we swapped and all was looking good.
Mt Buller will allow downsize too... they are also AASA.
Ok so I've now sobered up enough to remember one of my best non-driving moments of the rally...
I was standing talking to Jim Richards :banana: as you do :laugh: when I got an unprompted text through from Duncan saying *Don't forget to tell Jimmy we love him if you see him!!!*
GOLD! :ban:
Jimmy's a legend!!
can anyone tell me what the maximum rolling diameter difference a gtr will genrally aloow for?
Is 295/30 = 661mm & 235/35 = 652mm to big of a difference to fit to a GTR?
any info is appreciated.
cheers russ
  • 3 weeks later...
  • 4 weeks later...
also got the paddle shifter modto move with the steering wheel, thanks beerman!!!
Hi Giant,
Do you have any more info on the modification to the paddleshifter that you are talking about there ? Was it an Australian modification or a part you imported from overseas ?
The MCR paddle shifter kit is made by Works Bell, and the standard Works Bell paddleshifter moves with the steering wheel, so I'm a bit confused as to what modification you are talking about there - is it in terms of the connection between the paddleshifter and the contacts on the steering column ?
I'm curious as to what the modification is that you are talking about above and if it is a modified part that is R35 specific or otherwise.
Thanks,
Adam
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
