Hey guys, Looking for Fabricators that are well known for the craftsmanship in Melbourne to make me a Metal intake pipe for for turbo. It has to line up wit the factory Air box and i will be using the plum back BOV so must be able for me to plum it back in using the stock piping with minor modifications.
If anyone knows a good fabricator in Melbourne, preferably in the western suburbs. Please Leave me a PM
Cheers guys =]
https://www.sau.com.au/forums/topic/233549-metal-intake-pipe/
http://www.skylinesaustralia.com/forums/Lo...ops-t13305.html
Any of the workshops there will have contacts for fabricators... OR hav fabricators that work inhouse.
Give the ones closest a call
Also Kane - you gotta reduce that signature size dude
http://www.skylinesaustralia.com/forums/boardrules.html
1 Keep signature images to within 600x150 pixels
2 Combined Text and Image signatures to be kept within 600x200 pixels
Cheers boys
Ash
You can make your own with a piece of stainless steel pipe, cut the factory rubber one at a certain point, insert the steel and clamp at both ends...
Might sound dodgy when written like that, but it works perfectly and looks almost stock. There's a DIY with pics floating around somewhere...
JPC in Thomastown on err.. Lipton Dr, off Mahoney's Rd, same rd as Centreline
http://www.jpc.com.au/
they did nice work for me a while back
Or theres Glenroy Exhaust in Somerton
http://www.glenroyexhaust.com.au/
but.. from memory I went back caus the welding (intake pipe) was really messy on the inside and there was a small hole in one of the joins/seams... so I pretty much only go there for pieces now and DIY (Drive It to Your.. friendshouse&makethemdoit) haha
bonus with this is you still have play with the factory rubber hose
unlike the full metal one if its off a little it wont fit and you wasted your monies
JPC, nah dont like them..
Thanks for all the help guys.. I like Dez's Idea.. any one selling a Stock turbo to air box rubber hose thingo?
Protek in Thornbury? I really enjoyed it when they left coolant (dripping from someone else's car) on my bonnet all day.... it was still there when I picked up the car.. I have a lovely 'racing stripe' down my bonnet now... noice.
Aircon doesn't work still.. win-win situation.
Protek.. Not a big fan. got my Breaks done on my 180sx a few years back and they forgot to tighten the front left caliper bolts.. on the ring road back home, it fell off and tore up my inside of my left rim.. Dom said sorry, Didn't even offer to pay for damages...
im guessing you want this to stop the intake pipe from sucking closed (if you want the noise you need to remove your bov) try one of these http://cgi.ebay.com.au/SKYLINE-R33-34-GTST...1QQcmdZViewItem they get listed in black from time to time.
  • 3 weeks later...
Na dont want that noise... Just want a Metal intake pipe... Apexi sells em.. Nugan has em for like $550...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
