  • Replies 588
Posted Images
and i doubt it!! hmmm weres charmaine?
yeh our own chick in next to nothing showing off our cars hahaha...
Umm, I think we'd need to ask Charmaine to volunteer for that role :D
Or we could just drug her, kidnap her and string her up like a scare crow infront of the cars LOL
Hahahaha you guys are plotting against me!!! :D
Bonds? :);)
Steve (steveP - silvia) actually told me about it cos hes going, said i should go. Would be hella keen to take some photos.
So i guess i'll be there....just needa figure out what to wear? :D hahaha
oh and how im getting there LOL shotgun a lift
I did have a previous invite for this with Team Southern Hi Tech, but unfortunately my 21st is that night so gonna be impossible for me to attend.
Edited by Damo_R34
Well I think its an alright idea Craig. Not overpriced like Autosalon and if you turn it into a road trip/camping trip holiday, I'm sure some SAUers would go.
:D
Yeah. Its a nice cruise up there and Kadina is a decent sorta place, close to wallaroo and moonta (my relaxation spot of choice)
anyone for fush n chups afterwards? heh
-D
I will be interested but have to check work schedule etc..
Often the country shows are much more fun than the city ones coz of the relaxed atmosphere. Sure there are probably gonna be a whole stack of hicks that only know ford and holdens... but that is half the fun!!
I remember a few years back going to a country show where the local copper put his pursuit car on the dyno then we got shanes 180sx (PURESX) and kicked his ass!!
Put me as a maybe at this point.
Cheers, Martin.
yeah ill be there for sure. know a few people up there so a good excuse to go visit. i was at the first show 2 years ago and was a pretty good day. a large variety of cars. but damn it got hot, no shade and in the middle of a football over. and was stock commo after commo doing the dyno making their power stoppin 96kws or whatever a 3.8 ecutek makes. typical country bogans tho thinking their cars are surpreme, then a 32 made like 190+ on the dyno and shut them up.
but was a good over nite trip. the local car scene was hillarious. they got a 'rundle st' like main st and its one way so the same people just go around and around. it was commo, commo, commo, falcon, commo, commo, magna, commo.
but yeah worth the trip up there.
if a few of u guys are going we could organise a camping gound for the nite.. or caravan or whatever they got up there. would be a good lil weekend.
Edited by steveP
only if i had a definate answer as to whether my car would be ready by then or not
if everythings is sweet then i might join ya craig
if not then unfortunately i wont be making it to this one
have a good one anyway
i personally wont be staying the night, as the car show n shine is only on the saturday, the sunday, is the ''big rig''
show n shine, but hey, if people wanna organise to stay the night go for it! :(
i called mark today, and got the address to send entry forms and payment to.
so for all those that are going to display with us, please pm me, so i can pass on my address to you
to forword payment and forms, or we can work out a suitable time for me to collect it.
dont mean to be a rude bugger here, but could you take the dribble to the waste land?
cheers
adam, enter the gtr? the torana's will be represented i high numbers,
you/we will get more attention in the GTR :(
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
