How hard is it to drop the shaft to make a GTR 33 run in RWD only?
Does anyone have a step by step?
Or pics etc?
How hard is it? Anything needed to do it?
Just looking at going to an event and it has a dyno, but only a rear wheel drive dyno...
Any help would be good thanks
Ps not sure if its the right section soz!
https://www.sau.com.au/forums/topic/233703-dropping-the-shaft/
it will take about 10 min max. You need 2x12mm spanners (preferably 1 of them a ring spanner as it might be tight). Also a 14mm socket or spanner to remove the clutch slave cylinder.
just jack the drivers side of the car up and unbolt the 2 14mm bolts holding the slave cylinder on, then let that hang out of the way and undo the 4 12mm nuts and bolts on the front diff end of the front shaft. Remove all 4 bolts and pull the shaft away from the front diff and the front flange will drop down and then pull the shaft towards the front of car and the gearbox end will slide out. The gearbox hole is sealed so dont bother worrying about fluid leaking out or anything. Then rebolt the clutch slave cylinder back on and away u go.
Edited by unique1
Go buy a white and another colour paint pen and mark the edges of the shaft with the pens so you know the exact location when re-assembly is required.
I've seen the R32 boys pull a fuse and stop the 4WD that way, sorry dont know too much about the R33's.
On my 4WD laser I was told never to do this-disconnect the shafts- by plenty of people as it can really mess things up.
Have used the paint pens when removing just about everything from hoses, vacuum lines, doors, boots & tailshafts when replacing clutches and the like and its never failed there :(
and its just as easy to put back in???
Also i cant damage anything by doing this?
and no fluids at all will leak???
cheers mate
yes its as easy to put back in, no damage at all, no fluid will leak. I do this on my stagea (running gtr driveline) everytime i do dyno tuning and never caused an issue, i also drive around alot of the time with shaft removed and no problems.
  • 10 months later...
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
