i am planing on wiring up my house so need some cat6 cable. i can get some off ebay but the rolls are 300m which is too much, plus postage would be a killer, got many rolls of cat 5e cable at work but not good enough for gigabyte network. hence if someone works in IT and has a half full box of cat6 cable then let me know. might be able to work some cash etc your way.
https://www.sau.com.au/forums/topic/233894-need-some-cat6-cable/
if your going to do and insist on gigabit at home, i see no need for it, but if you do
get a real gigabit switch, not a junker $100 layer 2 switch
the cheapest real gigabit switch i can find from cisco is the 3508
its an 8 port GBIC switch so you need to buy base T copper gbics for it as well
you can buy them in 4 packs form ebay as well
NEW 4-Pack WS-G5483 1000Base-T GBIC Module 1-Yr WARRNTY
so get 2 packs of those and your set
the 3508 will do true gigabit switching, jumbo frames, vlans, management, snmp
and a stack of other cool tricks, ether channel, spanning tree
also if you find its noisey, you can replace the fans with 5v fans instead of 12v fans (i did this to mine)
gbics for it
http://cgi.ebay.com.au/NEW-4-Pack-WS-G5483...VQQcmdZViewItem
3508
http://cgi.ebay.com.au/Cisco-WS-C3508G-XL-...1QQcmdZViewItem
failing that check out some dell gigabit switches they usually go cheap as no one wants them
and should be fine for home
While I can't help you with the roll's, if you need some premade Cat6 cables and you can come down to Knox City on a weekend I work at Harvey Norman there and im happy to help you out.
Getting a bit carried away there aren't you Paul.
It's only for a home install. :(
Edited by Mean_R34
hmm thanks guys, unfortunately dont have net and the current place so didint post a reply.
it is for home use, basically i would prefer to use cat6 cable as its slightly better,, the keystones etc will most probably be 5e (yeah that defeats the purpose but it is easier to replace the connectors then the cables, also a work mate prefers cat6 cables, as i said we got about 6 half used boxes of cat5e sitting and no one is going to use them).
actually i was looking at a few gig switches on ebay one of the cisco one went for 171 and another went for 31 (and i wasnt happy about that one :huh: ). the other is that i am thinking of having a box with hard drives (something like nas) and was most probably going to get a switch which can agregate link (so 2gb if needed for the nas box)
i have found someone who has an account with middendorp so will most probably go via him to get some cable and connectors etc.
thanks for the help.
go nuts most of the catalyst switches will do etherchannel
but keep in mind most of the nas boxes wont support etherchannel
not to mention actually sustain more than 1GBPS of throughout
the only nas box that will sustain over 1GBPS and do etherchannel
is going to be a true scsi or SAS based array and it would be a $5k box easy
all of the cheap NAS boxes which take 1,2,3 or 4 sata drives usually run an embedded linux os
so its software raid instead of a ram chip backed raid setup so the performance is pretty ordinary
it would be unreasonable to expect near gigabit performance from a setup like that
they come with gigabit mainly cos its probably cheaper than 100mb chipset
my dlink 323 has a gigabit port and the most it can sustain is about 80mbps
after that its starts to max its cpu when running smbd
it might be a touch faster with NFS but its main bottleneck is CPU
its only a little embedded ARM cpu at 300mhz so its not geared up for it
yep
anyway this is one of the switches i was thinking about, just waiting on it to go for cheaper cuz i can get a linksys (new) for 400 delevered.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=300252392409
the box that i am considering at the moment for nas is a hp storage works dl100 server. it has hardware raid with SATA drives, quite good price
yeah the dell switch is fine, they are always chepa
check that it does jumbo frames and check the server or nas you are buyting does jumbo
otherwise you may as well stick with normal 100mbps
is the hp server big and loud?
i was goign to get an old dell powervault or poweredge nas server
but its a big clunky box thats loud and blows lots of hot air
not suitable fora small study in a house :huh:
re the noise that is a good question, i am waiting on reply from the guy about it, it is a 1U server. anyway it will most probably live in my store room so as long as it is not like the last HP server that i had which sounded like a jet taking off it should be fine.
